Author Topic: 1/3rd scale V10  (Read 294669 times)
Offline keith5700
Re: 1/3rd scale V10
« Reply #150 on: May 05, 2015, 10:14:16 PM »
Yes, spot on. 93 cuts in total though. My dividing head is 9 degrees per turn of the handle, so that was the angle between cuts. I've just cut the second one tonight, that went really quick. Need to turn the telly off, and get into a routine. 3 hours for the second one. Don't want to make another ever though!
Offline billmac
Re: 1/3rd scale V10
« Reply #151 on: May 05, 2015, 10:52:17 PM »
Keith -
"My dividing head is 9 degrees per turn of the handle, so that was the angle between cuts. "
Ah yes, I should have thought about that. I can well understand your reluctance to repeat the job. Superb work.
Offline keith5700
Re: 1/3rd scale V10
« Reply #152 on: May 12, 2015, 07:54:27 AM »
Moving forward, the first step was to check the centre distance of the drive gears. theoretically it should be 22.05mm. It showed that anywhere between 22 and 22.1 would work ok.
I decided to get the rotors to mesh at 22mm centres and then run them at 22.04 centres, so hopefully they wont touch.
I put the end holes in after the rotors were done, so I knew the holes were concentric.
I ended up lapping them together with grinding paste.
Re: 1/3rd scale V10
« Reply #153 on: May 12, 2015, 09:30:22 AM »
What can I say but 'WOW' ?  :praise2:  :praise2:
Offline Greg Haisley
Re: 1/3rd scale V10
« Reply #154 on: May 12, 2015, 12:58:54 PM »
  Beautiful craftsmanship and anodizing Keith!!!
Cheers,
Greg Haisley
Offline cfellows
Re: 1/3rd scale V10
« Reply #155 on: May 12, 2015, 02:27:21 PM »
Wow, would never have guessed something like that could be done in the home shop.  Nice work!
Chuck
Offline KB
Re: 1/3rd scale V10
« Reply #156 on: May 12, 2015, 03:48:24 PM »
That was certainly worth all of the effort put into that superb set-up. Outstanding!
Re: 1/3rd scale V10
« Reply #157 on: May 12, 2015, 08:03:23 PM »
Speechless but still following along.
Offline mike mott
  • Alberta Canada
Re: 1/3rd scale V10
« Reply #158 on: May 12, 2015, 08:21:29 PM »
Amazing piece of work, also the set up to get there.
mike
Offline DavidF
Re: 1/3rd scale V10
« Reply #159 on: May 13, 2015, 03:11:01 PM »
How did you model the rotors? Ive been trying to figure out a set myself. 2 lobes is pretty easy, but 3 lobed has been another story.
Offline keith5700
Re: 1/3rd scale V10
« Reply #160 on: May 13, 2015, 09:16:37 PM »
Thanks again chaps. David, I googled 'supercharger rotor' and clicked images, and about 15 rows down, on the iPad, there was a drawing of a 3 lobed rotor. I drew this on autocad and then scaled it up to my size.its only 2d cad, so I meshed 2 rotors together and then spun them at 10 degree intervals to check the fit.
They were almost bang on, but I altered the profiles slightly to get them perfect and then made the machining drawings.
I milled the whole profile with a 10mm ball nosed cutter, in 9 degree intervals. I can let you have my drawings if they are any use, although I would rather wait until I spin them up and see if they produce any pressure first. I should know in a week or so.
Best wishes Chuck.
Re: 1/3rd scale V10
« Reply #161 on: May 13, 2015, 10:28:17 PM »
Very impressive work Keith, that looks amazing.........I like.................. :praise2: :praise2:
Offline Steve76
  • Jr. member
Re: 1/3rd scale V10
« Reply #162 on: June 26, 2015, 07:20:53 AM »
Hi, is there any recent news on your incredible V10 project? you're doing something I can only dream about doing and I can't wait to see and hear it running.
Hope its going well,
Steve de Adman
(wannabe model engine builder)
Offline keith5700
Re: 1/3rd scale V10
« Reply #163 on: July 24, 2015, 01:23:14 PM »
Well, I'm still here. Seems I'm not much of a poster, or photographer, but I have a few pics to bring me up to date.
I made the housing for the supercharger rotors, and the gearbox housing, and then ran the rotors together with the helical gears fitted.
there was loads of interference with the rotors, so I just ran it for a bit and then removed the contact spots, and then ran it again.
This time it contacted somewhere else, so I removed those points.
Anyway, I went through this rigmarole about 12 times and they were still catching. It turns out that even though I'd closed the theoretical centrelines of the gears up a couple of thou' there was still too much backlash between the gears to keep the rotors where they should be.
there is about 4 thou' movement at the rotor tips. This needs to be 1 thou' at a guess. I ordered some gears with slightly longer centerline and I'm going to mesh them together with grinding paste, to get almost zero backlash at the centres I'm now stuck with.
Sorry for brief explanations, I don't get long for lunch here.
Pics will have to be self explanatory for the time being:-
Re: 1/3rd scale V10
« Reply #164 on: July 24, 2015, 03:10:30 PM »
Magnificent as ever  :praise2:  :praise2: Still following and learning  :ThumbsUp:  :wine1:
