Author Topic: Dale's k 27 By Kozo  (Read 41521 times)
Re: Dale's k 27 By Kozo
« Reply #60 on: May 02, 2014, 02:44:21 PM »
« Reply #61 on: May 02, 2014, 05:10:23 PM »
For my A3, which is approximately the same weight as your K27 will be (depending on boiler construction), there are 4 spring packs of 1/2" wide spring steel, 6 leafs each.  The steel is pretty hard, but I had no trouble machining it with carbide tooling.  Since the K27 has many more packs, I wonder that they are more for looks than for actual suspension.
Offline AndyRDG1175
  • Bel Air, MD....USA
« Reply #62 on: May 02, 2014, 07:33:00 PM »
Hey Dale...the pics look great!
Go ahead and post more of them over in our group...
Your package will go out this weekend. Monday at the latest.
Andy
Liam Locomotive Works on Facebook
Offline dalem9
« Reply #63 on: May 06, 2014, 11:59:03 AM »
Here Is a picture of the spring holder . I am useing # 12 copper wire to hold and them will use for the rivets . These took hours to make . But finally got them done . I am not going to drill the center hole until I can put it all together and make sure everything lines up . Thanks Dale
Offline dalem9
« Reply #64 on: June 22, 2014, 11:07:45 AM »
Hi everyone here are some more parts for my train . All done except for the pins and some holes to be drilled . Thanks for looking in Dale .
Offline stevehuckss396
  • Sterling Heights, MI
« Reply #65 on: June 22, 2014, 12:55:52 PM »
Nice work!
I know it's not an engine but I love the loco builds. I wanted to build one 30 years ago and never though I would have the skills or equipment. Keep up the good work.
Offline dalem9
« Reply #66 on: September 16, 2014, 10:57:05 AM »
Here are picture of the springs they are done.
Offline dalem9
« Reply #67 on: November 17, 2014, 12:54:39 PM »
Here are some more pictures of what I have done .
Online b.lindsey
« Reply #68 on: November 17, 2014, 04:10:42 PM »
I missed the last update until this morning. Both the springs and the cylinders look great. You are making some nice progress on this fine project!!
Offline dalem9
« Reply #69 on: November 20, 2014, 03:04:03 PM »
Well all I have left is to paint everything . I think I will put a clear coat on the covers ,what do you guys think
Online b.lindsey
« Reply #70 on: November 20, 2014, 03:30:37 PM »
Personally I like the contrast of the brass covers Dale, just depends on whether you are going for a more "real"  (painted) appearance or a more model type (clearcoat) appearance. Really looking forward to seeing everything assembled too!!
Offline dalem9
« Reply #71 on: December 13, 2014, 11:59:49 AM »
Here is some of the brake system
Offline dalem9
« Reply #72 on: January 30, 2015, 12:43:13 PM »
Hereare some more parts .
« Reply #73 on: January 30, 2015, 01:06:03 PM »
That's a neat way to make the brake blocks  :ThumbsUp:  :ThumbsUp:
Online b.lindsey
« Reply #74 on: January 30, 2015, 01:50:12 PM »
Dale, nice to see you back on this project...looking good!!
