Author Topic: No Fog Coolant Mister  (Read 10047 times)
Offline TerryWerm
« on: January 06, 2014, 02:49:27 AM »
I am working on a no fog coolant mister for my milling machine, and have drawn up the plans that are attached below. The only critical sizes are the .040" hole in the mixing block, and the .040" hole in the nozzle. The air passage in the mixing block should stay about the same size also. Everything else can be changed.
I do not yet have a set of plans drawn in metric, but will see what I can come up with over the course of the next week.
There are seven separate pdf files in the zip file, one for each page of plans. The bill of materials page also includes sources for most of the items I used.
Terry
Making chips when I can!
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: No Fog Coolant Mister
« Reply #1 on: January 06, 2014, 03:01:59 AM »
Wow!  That's very kind of you to share your design. Thank you.
Offline TerryWerm
« Reply #2 on: January 06, 2014, 03:37:50 AM »
No problem, Steamer. I kinda figure that's what this place is all about. I have started making mine, and am taking photos as I go so that I can post a build thread when it's done. Problem is that my machines are currently all out in my garage and it's -16*F out there right now. You can get frostbite just touching the handles on the mill! All I need is one warmer day (expected later in the week) to drill the holes in the mixer block and to make the nozzle. The rest I can do indoors where it's warm. So, if there aren't too many things getting in the way in the near future, I should be able to get it all built and ready to go in the next couple of weeks.
Terry
Offline AussieJimG
  • Bywong, NSW, Australia
« Reply #3 on: January 06, 2014, 04:46:04 AM »
Thanks for sharing Terry, I have filed it away for a little while but I do need one of these.
Offline cfellows
« Reply #4 on: January 06, 2014, 05:40:22 AM »
Thanks for the plans, Terry.  What kind of coolant do you plan to use?
Chuck
Offline TerryWerm
« Reply #5 on: January 06, 2014, 05:57:03 AM »
CHUCK!!!!  Glad to see that you are feeling better. I know that the flu bug going around is pretty ugly.
I plan to use Kool Mist, though a person could use any light coolant, even soluble oil if one wanted. I have used Kool Mist in the past, and really liked it. A friend of mine built a no fog mister similar to mine and he has his set up with two regulators, one for nozzle air, and one for coolant, but has only one needle valve for the coolant. I am thinking that this one should work well with one regulator and two needle valves, one for the air and one for the coolant. Time will tell for sure.  Anyway, this friend of mine has used his for several hours already and has only gone through a few ounces of coolant. He sets his so that the air is blowing just hard enough to keep most of the chips pushed away from the cutter, but is not blowing them all over the place. Coolant is set so that the target area is barely getting damp. Between the cooling effect of the expanding air and the evaporative cooling of the coolant, he is finding that his parts and cutters are ending up cooler than the ambient air.
For aluminum I will still use a dab of WD40 in a spray bottle, as I think it works better than Kool Mist on aluminum.
I do plan to do a build thread on this once I get mine all done. I am taking photos as I go so that I can post those also. If it ever warms up enough in the garage to do some machine work (it's -18*F out there at the moment) I will get the nozzle, the mixing block, and the hose nipples made. Once they are done I can do the rest of the work sitting at the kitchen table. I hope to have it all built within the next couple of weeks if work doesn't keep me too busy.
Terry
Offline gerritv
  • St Catharines, ON
« Reply #6 on: January 06, 2014, 01:44:41 PM »
An elegant design, thank you.
What level of air pressure is required to run this?
Gerrit
Offline Stuart
  • Tilchestune UK
« Reply #7 on: January 06, 2014, 01:59:29 PM »
For us lot in the UK  the canisters quoted can be found here
http://www.ro-world.co.uk/acatalog/10inch_Filter_Housings.html
« Reply #8 on: January 06, 2014, 02:44:26 PM »
That's a nice design Terry. I will certainly follow along on the build and hope it works as well as you expect. Thanks for sharing the plans!
Offline TerryWerm
« Reply #9 on: January 06, 2014, 06:42:31 PM »
Gerrit
5 to 10 PSI (35 to 70 kPa) seems to be plenty for the guys that have built these in the past.
In the past?? Yes.  This concept is not new, nor is this type of coolant system. They are even commercially available, but are expensive. Many of these have been built, but nobody has any decent plans available. So, I took the critical dimensions and started from there to design my own. It was only logical to create drawings and share them.
Terry
Offline TerryWerm
« Reply #10 on: January 06, 2014, 07:06:11 PM »
For those of you that work in the metric system, here is a metric copy of drawing 6, which is the only one that has any critical dimensions on it. I apologize that some of the thread sizes do not convert directly over, I simply opened my drawing in my CAD program, changed over to metric dimensions and then created a new pdf.  I hope you find it useful and don't have too much trouble with the thread sizes.
Terry
Offline gerritv
  • St Catharines, ON
« Reply #11 on: January 06, 2014, 08:22:01 PM »
Thank you Terry, that is airbrush compressor territory. Which is perfect for me as I do most of my machining in a spare room in our condo.
Gerrit
Offline TerryWerm
« Reply #12 on: January 06, 2014, 10:10:10 PM »
You are most welcome, Gerrit. Another advantage you will find is that with no fog in the air, everything in the room no longer gets coated in a sticky oily film.  The estimated air consumption of this type of applicator is about 0.3 CFM. If your airbrush compressor is capable of that much air you should be in good shape.
Terry
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
« Reply #13 on: February 01, 2014, 06:08:52 PM »
Terry:
Did you finish the low fog miser? I'd like to build one but was waiting for a final evaluation. Did it work well? Any plan updates after building it (there are always plan updates after construction)?
Thank you for making the plans available. I've seen others but, as you said, no other complete plans.
Anyone else build one? Other comments?
Thanks.
Hugh
Hugh
Offline TerryWerm
« Reply #14 on: February 02, 2014, 09:53:28 PM »
Hugh,
I have started construction of mine, and have found a mistake on the Bill of Materials page, but it is minor. I will post a corrected version of that page however after construction is complete.  As for current progress, I should just go ahead and start a construction thread, but wanted to hold off a bit longer. Here in Minnesota we have been enjoying what I refer to as an 'old fashioned winter'. It seems to snow every other day, and when it's not snowing it's so cold that the thermometer never gets above 0* F.  My machines are out in my unheated garage at present, and plans are underway for a basement shop, but shop construction has taken a back seat to some other things of greater importance.  Anyway, I plan to finish my no fog coolant applicator in the next two or three weeks if things warm up enough that my hands don't freeze to the handcranks on my mill.  All I need is a good afternoon in the shop with temps above freezing to get the job done, then get it posted.
A friend of mine did build one, but he made his own design based on the same internal dimensions.  It works very well for him, and he  is very happy with it. When I get mine done, I intend to do a complete test, such as pushing it to high pressures and high volumes just to see if there conditions under which it will create a fog.  This would be done so that I can publish some working limits of the device so as not to develop expectations that run too high. Let's face it, if you use enough air volume at a high enough pressure, you will atomize some of the coolant no matter what. I think it would be good to know where that threshold lies.
Another individual indicated that he uses a standard Kool Mist system without creating any fog in his shop. I have used that system and it is good. It can be used at low pressures and air volumes without creating a fog in the air, but the threshold where the fogging problem begins is at a much lower pressure simply due to the fact that the coolant is drawn up by a vacuum created in the venturi of the mixing block. The action in the venturi by its very nature tends to atomize the liquid being drawn up. The no fog system does not use a venturi and supplies the coolant at a slight pressure,  reducing the atomization of the fluid.
Terry
