Author Topic: Bernay Build - MZT  (Read 35018 times)
Offline mzt
Re: Bernay Build - MZT
« Reply #45 on: July 30, 2012, 01:18:17 PM »
Here's a short video of my self dismounting engine (castle nuts are in order, there).
Working pressure goeas from 0 to 3bars, over that value the duct tape would cease holding the pipes in place and they would pop with a scaring bang.
<a href="https://www.youtube.com/watch?v=rIZO1hw88xI" target="_blank">http://www.youtube.com/watch?v=rIZO1hw88xI</a>
Marcello
This is a fitting job,
not a production job that can be measured in.
Offline ref1ection
  • Oshawa, Ontario, Canada
« Reply #46 on: August 01, 2012, 05:27:43 AM »
It looks great with lots of interesting action.  :cheers:
Ray
Indecision... the key to flexibility!
Offline swilliams
  • Canberra Australia
« Reply #47 on: August 01, 2012, 08:12:16 AM »
fantastic engine, well done  :pinkelephant:
Where can one obtain the plans for this from?
Offline Maryak
« Reply #48 on: August 01, 2012, 08:40:44 AM »
Marcello,
Beautiful build  :ThumbsUp:  :ThumbsUp:  :ThumbsUp:
Best Regards
Offline mzt
« Reply #49 on: August 01, 2012, 09:53:38 AM »
Steve,
here they are, two PDFs attached to the posts:
http://www.classicsteamengineering.com/index.php?topic=42.0
They are a lot of pages: don't let them scare You, that's a rewarding engine.
(At some point into the build I printed them at 16 per sheet, to gain a three or four pages 'index')
The picture You'll see there corrects an error into the one of the pages, showing the valve arms into the correct position.
Marcello
Offline mzt
« Reply #50 on: August 01, 2012, 10:06:59 AM »
Ray
Ray,
Yep! The pistons TCD/BDC occurring at different angles than the 0 - 180 deg.  of the crankshaft I was used to almost drove me mad when timing the valves.
Bob,
there's still a lot of small works to do to have it 'completed' with all the parts. Fact is I'm now running it instead of my machines.   ;D
Marcello
Offline swilliams
« Reply #51 on: August 01, 2012, 11:04:29 AM »
Thanks Marcello, it's an awesome engine. Really good of PatJ to put the plans out there.
Offline sbwhart
  • Live Long and Prosper
« Reply #52 on: August 01, 2012, 05:22:15 PM »
What a cracking engine Marcello fascinating to watch and a masterful build log
Thanks for showing
Just had a scan through of PatJ drawings very tempting   :mischief:
Stew
Offline ozzie46
« Reply #53 on: August 01, 2012, 05:24:32 PM »
  Absolutely magnificent.  :P :P :P
Offline Captain Jerry
  • Summerfield, FL USA
« Reply #54 on: August 01, 2012, 07:50:52 PM »
Very nice model and build story.  I followed all the way and loved every post.  Thanks for the show.
Jerry
NOTARY SOJAK
Offline Bearcar1
  • Chicagoland Area, USA
« Reply #55 on: August 03, 2012, 05:33:42 AM »
Splendid build thread Marcello. I have enjoyed the entire ride. The video was a gas to watch as well.  :ThumbsUp:
BC1
Offline mzt
« Reply #56 on: August 03, 2012, 10:30:23 AM »
Thanks everybody for the kind words!!!
Marcello
In those last nights I've made a few small parts to have the steam pipes properly fitted. Ended with some bad words and the scrap box weighting a little more,
but I've got clearer ideas on how they should be.
Those scrapboxed (well, not all of them: quite a few have missed the landing area) ones may do for the 'modern materials' build: now I calmed down I gotta recollect them and have a check.
As for the plans, PatJ has recently released v12 of them (in a single .pdf file)  and  two PDFs about the 3d models of the parts.
Same address than before:
http://www.classicsteamengineering.com/index.php?topic=42.msg3598
Offline mzt
« Reply #57 on: August 08, 2012, 01:26:37 PM »
Some pipe fittings...
Here?s the second set I made, the first one went flying in direction of the scrap box when I realized I had
left not enough space to fit studs and nuts.
Later, I recollected them all: they might do with SH screws, on the ?modern materials? Bernay. I have not checked, yet.
While I was making them, I made myself a tool I should have made ages ago: nothing fancier than a short parting tool,
0.8mm wide, ground so it protrudes from the left of the bit. Works a treat when cutting the runout groove for a thread
against a shoulder.
..and pipe bending.
Material is 6.2mm external dia. 4mm bore copper pipe: first of all, I straightened  that short piece through forcing a
4mm steel rod through the bore. Results were not that bad.
Next, I chucked the cored pipe into the lathe, and reduced the ends to threading diameter: no way I could do that without
some support into the copper, then used a die to thread one end M6x0.75, the other end M6x1.
When it came to bending the pipe to a ?nice curve?, I wrapped a length of strictly coiled masking tape over it, put a couple
of marks where (I thought*) the curve should start and finish, inserted the 4mm steel rod on the long arm, till it reached
the start position and fitted a flexible core (plastic brushcutter wire, brought to diameter by wrapping some more masking
tape on it) into the other end.
Bent it over a 30mm rod set in the vice, using hands and a piece of 8mm inner dia. tubing to add some lever.
Here it is without the masking tape.
(*) It is obviously too short on the longer arm and too long on the short one, but that can be fixed.
Somehow.
Marcello
Offline mzt
« Reply #58 on: August 10, 2012, 12:55:07 PM »
Some hacksaw work
From this
To this
Plus a little drilling and tapping on the flanges: they came out well.
These 'finishing' tasks are never ending!
Marcello
Offline swilliams
« Reply #59 on: August 10, 2012, 01:09:56 PM »
I hear ya on that one Marcello
