Author Topic: Hemingway geared rotary table build  (Read 19022 times)
Re: Hemingway geared rotary table build
« Reply #15 on: December 27, 2013, 02:36:36 AM »
OK
Here's some photo's of the build thus far...
In this photo, the stub shaft is made, inserted and used as a mandrel to finish the OD turning and Grooving.
Should of had the blank cut longer.....but C.O.R.
Here's the nut turned and threaded .745-40.
The base blank......
After a trip to the saw
I am now squaring this block up in preperation for a trip to my lathe....and the table.....
Like I said....it's sitting.....I'll get to it.
Online sco
« Reply #16 on: December 28, 2013, 07:26:04 PM »
Well UPS let me down so still no replacement base to work on.  Instead I machined up the central pivot pin and the lock nut, here they are with the pad bolt.
Simon.
Ars longa, vita brevis.
Online sco
« Reply #17 on: January 02, 2014, 09:45:31 PM »
UPS finally delivered the package - looks like they've been playing football with it in the meantime but the contents seem to have survived.
Whilst waiting for the replacement base I've made a start on the table - the supplied stock is quite generously sized so there is an awful lot of cast iron dust to create.
Simon.
Online sco
« Reply #18 on: January 04, 2014, 07:51:42 PM »
The major operations on the table are now done - just needs the T slots and the radial holes drilling.  I Loctited the central pin in whilst the table was in the lathe and then did a final facing skim to make sure it was all on the same plane - hopefully I wont regret bonding the pin in for subsequent machining ops!
Simon.
Online sco
« Reply #19 on: January 09, 2014, 09:34:38 PM »
Been working on the base - haven't completely followed the build instructions so that I could mount it on the faceplate with four bolts.  The table fits though so, so far so good.
Simon.
« Reply #20 on: January 09, 2014, 11:32:30 PM »
Hi Simon, looks like it's finally starting to take shape. Nice work bud and I have been watching your progress. I have the non geared table to build and hopefully I can get some tips for doing mine.
Online sco
« Reply #21 on: January 10, 2014, 03:52:47 AM »
Thanks Don,  the non-geared version is quite different though so not sure how much you will pick up.
Simon.
Online sco
« Reply #22 on: January 12, 2014, 06:12:05 PM »
Hogged out the back of the base to make the pocket for the gear - this allowed a trial assembly so I couldn't resist.  With a drop of oil it spins smooth as silk, next job is the worm spindle  :)
Simon.
« Reply #23 on: January 14, 2014, 01:18:58 AM »
Cool Simon, they really look nice......... :ThumbsUp:
 :cheers: don
« Reply #24 on: January 14, 2014, 02:35:43 AM »
Nicely Done Simon!
Online sco
« Reply #25 on: January 18, 2014, 08:23:23 PM »
Spent the day making bits for the worm assembly - started with the main tube which has the central hole drilled slightly eccentric so that you can adjust the worm mesh.  Then drilled and reamed the brass bushes 1/4" to suit the supplied drill rod axle - all going too well!  I then checked the worm which is supposed to be supplied with an accurate bore to suit the 1/4" axle - nope bore was very rough and seemed more like 6.5mm - time for a rethink  >:(
Had some 7mm drill rod handy so decided to re-bore the bushes to suit and gripping the worm very gently in the chuck bored it out to 7mm.  Turned out ok I think so got on and made the main nut, tomorrows job is the micrometer collar and the hand-wheel.
Online sco
« Reply #26 on: January 19, 2014, 07:54:41 PM »
Today I screw cut the end of the worm axle - no fancy clutches for me so lots of lathe on / off / reverse / on / off repeat.  Also machined up the micrometer collar - used a small 45deg dovetail cutter to machine the graduations.
Simon.
Online sco
« Reply #27 on: January 22, 2014, 09:26:38 PM »
Quick shot of the assembly so far post lapping the gears together.
Simon.
« Reply #28 on: January 22, 2014, 11:33:18 PM »
Oh! I like that it's really taking shape and looking good.   :ThumbsUp:
« Reply #29 on: January 24, 2014, 03:05:55 PM »
Looking pretty cool Simon!
So what's the brass button in that left hand corner doing?  Does it hold the shaft in place?
