Author Topic: Potty Vertical Cross Single  (Read 22543 times)
Offline NickG
Re: Potty Vertical Cross Single
« Reply #30 on: January 24, 2014, 03:43:00 PM »
Looks great that Stew, like a casting. I was going I ask all the same questions - thanks for the write up.
Offline sbwhart
  • Live Long and Prosper
« Reply #31 on: February 01, 2014, 05:40:39 PM »
I've got it running
<a href="https://www.youtube.com/watch?v=Im9BVRQ6VJY" target="_blank">http://www.youtube.com/watch?v=Im9BVRQ6VJY</a>
Its a bit noisy but that will tune out bits are catching or have an headache but nothing that a bitter of fitting can't sort.
Its on a test base at the moment I want to fit it to a tile effect base,
I'm also going to make valve for it.
Stew
« Reply #32 on: February 01, 2014, 06:26:18 PM »
That runs great Stew!   Congrats!    Tell me about how you did the tiled base?......
Offline NickG
« Reply #33 on: February 01, 2014, 08:15:33 PM »
Looks great Stew, really good looking engine and runs like a good 'un too!
Online fumopuc
« Reply #34 on: February 01, 2014, 08:26:13 PM »
Hi Stew, nice first run. I am sure you will get it into a smooth movement by some fine tuning.
« Reply #35 on: February 01, 2014, 10:21:32 PM »
Like Dave, if possible, could you tell us how you made the tiled effect base.
Thanks
« Reply #36 on: February 02, 2014, 12:20:54 AM »
That looks and runs well Stew. I'm sure you will get the noise worked out. That tile base will look phenomenal!!!
« Reply #37 on: February 02, 2014, 12:29:24 AM »
Nice runner Stew..............   :ThumbsUp:
Offline sbwhart
« Reply #38 on: February 02, 2014, 07:14:57 AM »
I cribbed the tiling method from Jason he used it to make the base for his Benson engine.
Basically what you do is paint a lump of high density chip board with the base colour in my case this was white, then you cover the whole lot with frog masking tape then you simply mark it out and remove the bit of tape where you want it to be black, you then spray the whole lot black let it dry and then pick off the bits of tape to give the black and white tile effect.
This was my first attempt ended up with an orange peal finish to the black coat as I used spray cans from two different manufactures, my second attempt was much better using cans from the same supplier
Hope this helps
Stew
« Reply #39 on: February 02, 2014, 08:02:08 AM »
Thanks
« Reply #40 on: February 02, 2014, 08:17:50 AM »
Thanks Stew!    .....and Jason! 8)
Offline sbwhart
« Reply #41 on: February 10, 2014, 05:10:51 PM »
Well I've got it finished, struggled a bit with the wooden base, when it comes to woodwork I'm no Chippendale
 (I don't do exotic dancing either  :D)
And her's the video
<a href="https://www.youtube.com/watch?v=9pSGzl8Qt18" target="_blank">http://www.youtube.com/watch?v=9pSGzl8Qt18</a>
Stew
« Reply #42 on: February 10, 2014, 07:44:48 PM »
Nice one Stew.  A smooth runner.  Love that tile pattern base.
Online fumopuc
« Reply #43 on: February 10, 2014, 08:33:12 PM »
Hi Stew that is a very nice engine. I like this kind of steering and the motion, specially if it runs very  slowly.
Offline NickG
« Reply #44 on: February 10, 2014, 09:55:06 PM »
Looks really good Stew, love the paint scheme.
