Hi Roger,
The two lathes that I repaired were not Sieg either, I had chance to borrow a Sieg lathe when I was designing a version of my screwcutting clutch to fit this lathe, they are quite well made I found. I also designed a Handwheel dial with a zero-able Dial to fit this lathe while I had it. The dials read 0-1" or 0-25 mm if you prefer, both these attachments are due to be published in the New Year.
I have attached a couple of photographs of both items.
My best regards
Gray,
