Author Topic: 16 valve engine  (Read 33469 times)
Offline smfr
Re: 16 valve engine
« Reply #75 on: April 13, 2014, 04:27:14 PM »
Interesting to see the powder-coating process, Achim. Thanks for showing it to us. This engine is looking better each time  :ThumbsUp: :ThumbsUp:
Simon
Offline ths
Re: 16 valve engine
« Reply #76 on: April 13, 2014, 10:04:43 PM »
Didn't know that you could do powder coating at home - I'd never thought of it. Looks great.
Hugh.
Re: 16 valve engine
« Reply #77 on: April 14, 2014, 05:52:44 AM »
Hi Hugh, two options, two different systems,
http://www.ebay.com/itm/NEW-Complete-Electric-Powder-Coat-Gun-system-with-WAI-powder-coat-sample-/301146779459
or
http://www.electrostaticmagic.co.uk/products/powder-coating-system-1
I use the WAI system. It is working like a hair dryer.
The Easy Coat should be more professional, I have heard, but never tried by myself and it is more expensive.
Offline ths
Re: 16 valve engine
« Reply #78 on: April 14, 2014, 08:36:39 PM »
Thanks for that Achim, something else to delve into, I guess!
Cheers, Hugh.
Re: 16 valve engine
« Reply #79 on: April 14, 2014, 09:16:44 PM »
Hi Achim
Like Hugh, it never crossed my mind that it is possible to do powder coating at home.  More things for the wish list.
Offline NickG
Re: 16 valve engine
« Reply #80 on: April 15, 2014, 07:52:08 PM »
Interesting that Achim, out system at work requires 'gelling' then 'curing' do you have to do both or just heat once?
Re: 16 valve engine
« Reply #81 on: April 15, 2014, 08:12:08 PM »
Hi Nick, also here, after putting the coated part into the oven, it takes some time, maybe 5 minutes until the powder starts to flow. It starts to shine and from this point is has to stay by  180° Celsius for 10 minutes in the heat. Take it of and finished.
Re: 16 valve engine
« Reply #82 on: April 21, 2014, 07:30:52 PM »
Hi everybody,some more piping is done and the oil-separator is fixed in the basement. Here some pictures from the progress. Pipe bending, by a simple master, drawn on a wooden plate, some black burnishing and final installation. Happy eastern.
Re: 16 valve engine
« Reply #83 on: April 21, 2014, 09:07:36 PM »
What is that blue solution?  Copper Sulphate?
Re: 16 valve engine
« Reply #84 on: April 21, 2014, 09:51:09 PM »
Achim, nice process for doing your plumbing!
Does the same blackening solution work for both brass and copper?  I thought it took different solutions to blacken the two metals.
What ever you did, clearly works though!  Your work is beautiful, as always!
Re: 16 valve engine
« Reply #85 on: April 22, 2014, 12:36:52 AM »
Achim this is nothing but pure art my friend. Your craftsmanship it is superb. I like............ :praise2:
Re: 16 valve engine
« Reply #86 on: April 22, 2014, 06:16:18 AM »
That's a stunning engine Achim and has a very nice appeal to it. I ilke.......... :ThumbsUp:
Simon the blackening can be done with Selenium Dioxide (selenium acid) for brass and copper.
Hi Vince, Hi Kim, Don has already given the right explanation for the process. Only the tin-solder will stay untouched. I use a black Edding marker to correct this. Thanks for your friendly comments.
Re: 16 valve engine
« Reply #87 on: April 22, 2014, 06:19:45 AM »
Hi Don, thanks for your friendly words and the compliment.
Offline Chipmaster
Re: 16 valve engine
« Reply #88 on: April 22, 2014, 06:26:22 AM »
Hi Achim,
I am inspired by your 16 valve engine, the presentation is perfect.
I have finished a Stuart Twin Victoria and hope to make a base like yours if I can obtain the right materials.
Andy
Re: 16 valve engine
« Reply #89 on: April 22, 2014, 06:34:28 AM »
Hi Andy, if you need any help for getting the right stones or tiles, let me know. Thanks for your compliment.
