Author Topic: 16 valve engine  (Read 27525 times)
Re: 16 valve engine
« Reply #30 on: January 01, 2014, 03:03:18 PM »
Nearly there Achim.  When it's finished it is going to be a wonderful model.  Really love what you did to the base with the tiles.  I might do something similar to my build.
Offline NickG
Re: 16 valve engine
« Reply #31 on: January 01, 2014, 03:04:37 PM »
Fantastic and only running on 2cyl !
Re: 16 valve engine
« Reply #32 on: January 01, 2014, 05:00:37 PM »
Beautiful work Achim!
Thanks for answering my question; that was helpful.
Re: 16 valve engine
« Reply #33 on: January 06, 2014, 05:02:50 PM »
Hi everybody, the last weekend was a good one. In Bavaria we have had an extra bank holiday today. I have made this weekend the first real parts with my CNC toy for a current project. It was the last batch of 8 eccentric rings for the 16 valve engine. My CAM is the VCarvePro and I like it. I have made 6 different tool paths for this job.
#1 machining lower side of the part in two steps 3,1mm deep each, with an oversize of 0,2mm to the final outline.
#2 synchronous milling of the last 0,2mm in one go over all
#3 milling the 0,5 mm section ( circle)
#4 machining the upper side, outline in two steps like above, with 0,2mm oversize
#5 synchronous milling of the last 0,2mm in one go over all
#1 to #5 was running in one go
#6 Finally I had to turn the parts around and milling the 0,5 mm section (circle) on the other side.
tbc
 I try to sent this post with pictures, all under 130 kb each, but no chance.
I get these message
Forbidden
You don't have permission to access /index.php on this server.
Re: 16 valve engine
« Reply #34 on: January 06, 2014, 05:10:51 PM »
two picture only...
Re: 16 valve engine
« Reply #35 on: January 06, 2014, 05:14:43 PM »
only one...
Re: 16 valve engine
« Reply #36 on: January 06, 2014, 05:17:43 PM »
I leave it now, it is really frustrating............
Can not upload the pictures.
Offline smfr
Re: 16 valve engine
« Reply #37 on: January 06, 2014, 05:26:57 PM »
Achim, the pictures on your last two posts came through fine!
Another option is to upload the photos to some other service (Flickr, Photobucket etc) and insert links to them in your posts.
Simon
Re: 16 valve engine
« Reply #38 on: January 06, 2014, 07:10:57 PM »
Achim,
  I was getting exactly the same 'Forbidden' error when posting, and arnoldb was able to help me out. Neither Arnold or I can explain it, but when I changed my profile to default to the WYSIWYG editor, the problem was solved! It's worth a try.
Re: 16 valve engine
« Reply #39 on: January 06, 2014, 07:40:42 PM »
Hi Tim, thanks for your help and proposal, so lets try......
Finally where we are with the build today.
And again, the bits and bites are still pure miracles...
Offline smfr
Re: 16 valve engine
« Reply #40 on: January 06, 2014, 08:19:43 PM »
Wow you're making great progress on this engine, Achim! The floor looks great!
Simon
Re: 16 valve engine
« Reply #41 on: January 18, 2014, 03:39:53 PM »
Dear Lady and Gents,
first of all thanks for visiting my thread.
I have been able to finalize the main valve for the engine. Basic is a block valve from stock for 6 mm tubes.
I have made a disc from brass and fixed this disc by soft soldering to the cap nut of the valve spindle.
A spacer under the floor has given the right distance to clamp the block valve at the floor.
Then an extension was made for the spindle.
Now the hand wheel is in a comfortable position.
So I can start with the real plumbing now.
« Last Edit: January 18, 2014, 08:00:23 PM by fumopuc »
Offline smfr
Re: 16 valve engine
« Reply #42 on: January 18, 2014, 04:59:42 PM »
You'll be running soon, Achim! Did you make that handwheel, or buy it?
Simon
Re: 16 valve engine
« Reply #43 on: January 18, 2014, 07:52:39 PM »
Hi Simon, the hand wheel was part of the block valve I have bought.
May be somebody in Europe has interest about the source.
http://www.modellbau-niggel.de/
« Last Edit: January 18, 2014, 07:58:18 PM by fumopuc »
Offline Jack B
Re: 16 valve engine
« Reply #44 on: January 22, 2014, 01:35:51 AM »
Hi Achim: Your machining is A 1 Terrific. That is a very nice engine you are building. I joined this site just a short time ago and I put some time aside from my project to see what my new friends are doing. I wish you the best of luck and I will keep watching.                Jack B
Jack B
