Author Topic: starting scotch boxer steam engine project  (Read 9596 times)
Offline burnit0017
Re: starting scotch boxer steam engine project
« Reply #15 on: January 04, 2014, 02:00:01 PM »
<a href="https://www.youtube.com/watch?v=m2AyB1kPypI" target="_blank">http://www.youtube.com/watch?v=m2AyB1kPypI</a>
Hi, thanks, video shows manual operation using a 10 pound weight as a flywheel. I have to remove a few knocks and run the steam lines to each cylinder. I am using 3/8 brass rod for the spool valves. I am not sure how long the valve should be open? There seem to be a short dwell period at the end of each stroke.  Looking for a source for a large flywheel or possibly how to fabricate one.  Not much to look at and I am making a lot mistakes but the design seems to be very forgiving and the mistakes are easy to correct.
Offline Paul
« Reply #16 on: January 22, 2014, 09:48:05 PM »
Very nice, +1 from me!
I've built a couple of double-scotches with eccentric/yoke set up but I'm looking into building one with this 'whack valve' idea too, much smaller than this giant though!
Paul
Offline burnit0017
« Reply #17 on: January 25, 2014, 12:58:31 AM »
Hi, thanks. I made a lot of fabrications mistakes on version 1. Working on version 2. I hope to post some photos in a few days. I did find some off the shelf parts for the steam line between the two piston cylinders. The idea comes from another project posted on this forum.  I look forward to seeing your project.
Offline Paul
« Reply #18 on: January 25, 2014, 08:01:30 AM »
Proper plumbing! :D
Offline burnit0017
« Reply #19 on: January 25, 2014, 09:10:25 AM »
Hi, the copper tube may need to be insulated. I am not sure what to use?? Suggestions are welcome.  I checked your videos on youtube, the scotty and the double scotch are the source of inspiration when I started this project.
« Last Edit: January 25, 2014, 09:39:09 AM by burnit0017 »
« Reply #20 on: January 25, 2014, 12:54:27 PM »
Nice Vid!    Check out Stew's thread on the Potty Cross Single
http://www.modelenginemaker.com/index.php/topic,2890.10.html
Nice way to make a big flywheel.
Offline burnit0017
« Reply #21 on: March 20, 2014, 05:35:02 PM »
<a href="https://www.youtube.com/watch?v=3J9SEBgoTMY" target="_blank">http://www.youtube.com/watch?v=3J9SEBgoTMY</a>
Hi, first run of project on compressed air. There is a lot of blow by at the piston rings that will have to be solved but it is a start. :pinkelephant:
