Author Topic: Sixis 101 House Mill  (Read 125546 times)
Online sco
Re: Sixis 101 House Mill
« Reply #300 on: September 23, 2014, 09:57:19 PM »
Simon, you need one   :ThumbsUp:
:mischief: trust me. http://www.hemingwaykits.com/acatalog/Versatile_Dividing_Head.html
I remember asking before what the advantages of a dividing head were over a rotary table without getting a completely conclusive answer...
Anyway the question was more haven't you got one of these already so why make another?
Simon.
Ars longa, vita brevis.
« Reply #301 on: September 23, 2014, 10:02:37 PM »
That is like asking if it is possible to live with only one lathe  :ROFL:
Sexy wants a tailstock for his and the only way to get it matched with the main dividing head is to bore them both at the same time, the same as we had to do for the arms on the UPT at the beginning of the year.
I have also made a few minor modifications to the mounting on this one so that it can fit on Sexy's tilting table which I am hoping the castings have finished settling and shortly I will be able to get back to finishing it :whoohoo:
Online sco
« Reply #302 on: September 23, 2014, 10:11:24 PM »
Of course - I had momentarily forgotten your need for multiplicity in all things  ;D
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #303 on: September 23, 2014, 11:16:12 PM »
Of course it is Jo - I've been doing it for over forty years :o  It's like riding a bike - two feet - two pedals   :Lol:
« Reply #304 on: September 24, 2014, 06:03:44 AM »
In years gone by model engineers would have done everything on their lathes: Drill, Mill, cut gears etc. But IMHO it is normally easier to use a drilling machine to drill holes and a mill (or shaper) to make things flat. In the same way you can put indexing plates on a rotary table and use it as a dividing head.
Model Engineers are so ingenious in the way they use their tools, they can make so much with so little.  ;)
Offline Stuart
  • Tilchestune UK
« Reply #305 on: September 24, 2014, 07:30:46 AM »
Give your fella a treat and fit a stepper motor to the worm and get a division master controller ,and divide at will .
Very nice work and as usually very well documented
« Reply #306 on: September 24, 2014, 07:50:40 AM »
Don't really see why you can't bore the tailstock to withing 0.0005" of the head or better?
But would it not be more "versatile" to have a tailstock with adjustable height so you can index things like tapered columns to cut flutes etc? Handy for when you make that 1/24th scale Otto :LittleDevil:
« Reply #307 on: September 24, 2014, 07:57:15 AM »
I remember asking before what the advantages of a dividing head were over a rotary table without getting a completely conclusive answer...Simon.
A rotary table without indexing discs is only as accurate as you can read the venier scale
A Rotary table with set of 3 indexing plates is limited in the number of divisions it will give does depend on size of table as the larger tables take larger wheels which give more holes so more divisions available
A BS0 & BS1dividing head gives more divisions than the above
A BS2 Gives far more divisions than the above
  • Suffolk in the UK
« Reply #308 on: September 24, 2014, 08:06:55 AM »
Just a tease Jo - just a tease  ;)
« Reply #309 on: September 24, 2014, 08:14:34 AM »
Strangely enough I do have a tailstock to go with the Harrison dividing head which is height adjustable and used that to mill the columns on my Lady S. But as this VDH is designed to go on Sexy's tilting table so it won't be a problem  ;)
Jason you missed the effects of the size and orientation of the bearing surface. A horizontal rotary table has a large bearing surface to support the work. If used in the vertical mode is has a very small amount of bearing surface, where as the indexing head has a much wider bearing as it is designed to be used in that orientation (the VDH has a similair bearing area as the Myford S7B lathe headstock).
If you then use some sort of holding device in the centre of the rotary table to hold the work to move it far enough out from the surface of the table so that you can get your cutting head close up and personal with the piece of work you then start imposing even greater loads on the rotary table bearings due to the lever effect.
« Last Edit: September 24, 2014, 08:22:36 AM by Jo »
« Reply #310 on: September 24, 2014, 08:17:28 AM »
 :lolb: I know you are a one lathe man Tug
I am still looking for my perfect one  :mischief:
Offline tangler
  • Christchurch, UK
« Reply #311 on: September 24, 2014, 08:19:54 AM »
Bearing in mind that I've never done this so am talking out of my ar , er hat:  If you were fluting a tapered column would you not want the flutes to be tapered as well,so the cutting depth of the ball ended mill decreases as the diameter gets smaller? Or does it not work like that?
Rod
Offline tangler
  • Christchurch, UK
« Reply #312 on: September 24, 2014, 08:21:48 AM »
Everyone
knows that the Myford Super 7 is the perfect lathe  >:D
« Reply #313 on: September 24, 2014, 08:23:38 AM »
Everyone knows that the Myford Super 7 is the perfect lathe  >:D
I am selling mine  ;)
  • Suffolk in the UK
« Reply #314 on: September 24, 2014, 08:24:37 AM »
Lathe or man Jo  (or both :D ) good luck with your quest  :)
Now, I really am off to make some more swarf  :D
