Many thanks gentlemen
Hi Don I think Tim has covered the difference in the Ringbom design.
Hi Simon the tapping thingy is very handy and well worth the time in making one.
Its my first Ringbom so we will see how it goes.I have altered the design a little and was going to post the hot end build but for some reason my pics have evaporated from photo bucket
I will retake them and show how the test tube is going to be held instead of I think bonded in.There is a bit of guess work as I cannot read the text in the book although the drawings are of excellent quality and well worth the £6.50p the book cost
So onto the flywheel it is 20mm larger in dia than specified as I had some bronze alloy rings left over from my Little Angel build
First I just friction turned an alloy blank
As I dont have any large measuring kit it was a bit suck it and see to get the shrink fit
The blank was then set up and reamed for the center bosses Note to myself I must get a shorter 5/8 reamer but this one was for the best price FREEEEE
Then onto the mill to shot a few holes in I was going to use Steve's what the hell pattern but chickened out
Next up the bearing housing so after a rummage through the swag box I found some bearings near enough if a little larger than specified
I dont have a boring head so the bore was machined on the lathe and then mounted on a mandrel this mandrel will also be cut to make the bearing spacer .So not bad two parts for the price of one.
The housing set up on the rotary to for the round section
The excess was milled of and the bearings glued in. The crank is just again glued up
A little group shot of all the parts made to date
Thanks for looking in.
kind regards
frazer
