Ah but those were bolts not screws. Certainly BMC used studs. My current Ford has bolts as well.JerryNotts
Jo, does the drill chuck you use for holding while doing the second end not chew up the thread you've already done?
Quote from: derekwarner_decoy on November 14, 2013, 10:35:51 AM2. the nominal [minimum] depth of thread engagement is 1.5 x the thread diameterNo thread engagement is not how far the stud/bolt or screw is turned into the tapped hole.It is the relationship between diameter of tapped hole to the major dia and is expressed as a percentage. eg how much flank contack there is not how far the stud is screwed in. If the commercially produced rolled studding is undersize then the percentage engagement will be reduced.Quote3. I simply noted that BA is a metric thread formThe term "form" relates to the shape of the thread and as BA is not shaped the same as metric it can't be the same form. It would have been better to say something like "BA is a metric based system"J
