Author Topic: Drop Valve Engine  (Read 9822 times)
Offline Giraldus
Drop Valve Engine
« on: November 03, 2013, 04:42:03 PM »
Hi,
I would like to present my third beam engine.
It is again a Grashopper type, but this time following a historical exemplar. It was built by the american engineer Oliver Evans around 1801. In 1805 Evans published a book  "The Abortion of the Young Steam Engineer's Guide" (available online). In this book Evans described "a Steam Engine on new principles". Simply spoken his engine was using high pressure steam. Another outstanding feature was the linear guide for the piston rod, which later became known as Evan's linkage. There is only one drawing in the book showing the machine:
The engine was used to drive a plaster mill. You may find further details here.
Digging deeper into the history of Evan's machines I found the term "The Columbian Engine". This the first relevant drawing I found:
This was published in "The Emporium of the Arts and Sciences", Vol. II. presumably in 1812. The significant difference between the two drawings is the valve gear. In Evan's book dedicated intake and outlet valves are described, while on the drawing from 1812 no such valves can be seen. Matschoss mentions Evans using a rotary valve since 1812. I think such a rotary valve can be seen on the above drawing from "The Emporium of the Arts and Sciences".
Other sources mention that Oliver Evans destroyed his own plans in 1809, after a court case with the American Patent Office. Plans submitted to the Patent Office were lost 1836 in a fire.
So the two pictures are the only sources for the two machines, which are the first not atmospheric steam engines designed and built in the US as far as I know.
I finally decided to make a model of the very first machine described by Evans in his book. In the sources this machine usually does not have a name, only D. and G. Bathe referred to it as "Drop Valve Engine" in 1935. So this is the name I'm going to use.
I did not find any hints about currently existing models of the "Drop Valve Engine". So I really would appreciate any hints.
This is the base frame unfinished:
Now the carpenter has finished:
The valve gear:
So long for now !
Greetings
Gerd
Offline smfr
Re: Drop Valve Engine
« Reply #1 on: November 03, 2013, 04:51:46 PM »
This looks like it will be a fascinating build, Gerd. I look forward to more!
Simon
Offline Alan Haisley
« Reply #2 on: November 03, 2013, 05:28:26 PM »
With the little amount of information you have, it's going to be a really interesting build. I'm looking forward to following along.
Alan
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #3 on: November 03, 2013, 06:04:07 PM »
Popcorn is ready and refreshments in the fridge ...
Tom
Offline ths
« Reply #4 on: November 03, 2013, 07:36:40 PM »
The carpenter has worked nicely! Looks good.
Cheers, Hugh.
« Reply #5 on: November 03, 2013, 07:40:21 PM »
Welcome Gerd,
I followed your link and saw your other beam engines. Very nice indeed.
« Reply #6 on: November 03, 2013, 07:47:55 PM »
:hi: Gerd,
Nice beam engine make a model of  8).
Any chance of posting an introduction about yourself in the introduction section  :ThumbsUp:
« Reply #7 on: November 03, 2013, 08:44:50 PM »
Nice start on what should make a fine model!
« Reply #8 on: November 04, 2013, 10:48:47 AM »
Nicely executed Gerd!
Offline Tinkerer58
« Reply #9 on: November 04, 2013, 11:09:56 AM »
Nice work Gerd, I will be following this closely. It may help with my Newcommen project I'm working on, I will post some detail in a new post on that.
I just wanna be in me bloody shed.
« Reply #10 on: November 04, 2013, 12:28:31 PM »
Excellent fabrication. I like the others are watching the progress. Thanks for joining in.
Offline Giraldus
« Reply #11 on: November 15, 2013, 09:07:38 PM »
Hi,
thanks for all the kind comments.
The valves of the machine kept me busy for some time. The first attempt failed, simply because I wasn't machining precise enough. The second attempt seemed to be better, so I tested it together with the valve gear which I already have shown here. I was confident then and carried on with the model. An O-Ring was the sealing element:
When a real test became possible, I had to learn that these valves did not really work in motion. I think the main issue was the back pressure. I finally built a set of new valves. The valve body is now a simple piston, which is hit by the air under 90°:
This is an inlet valve in detail:
And the finished unit:
So long for now !
Greetings
Gerd
Offline Giraldus
« Reply #12 on: December 09, 2013, 10:24:33 AM »
Hi,
I finally finished the model. Quite a few square nuts and bolts had to be done - but this is 1801  ;D. Due to narrow space I even had to make a square socket key. The base plate is not yet finished. Eventually I will add some things.
Here are some pictures:
A front view first:
Now an aerial view:
Rear:
Here I added a scale:
This is a narrow space:
The crank:
If somebody wants to see a video:
http://youtu.be/wwg4Mfvb5cw
So long for now !
Greetings
Gerd
« Reply #13 on: December 09, 2013, 10:26:44 AM »
That is first rate work Gerd!
 :ThumbsUp: :praise2:
Got any build photo's?....... 8)
« Reply #14 on: December 09, 2013, 10:28:27 AM »
That is rather nice  :ThumbsUp:
Database Error
Back
