Author Topic: Pistons  (Read 6888 times)
Offline Marinus
  • Limpopo, South Africa
Pistons
« on: October 23, 2013, 10:12:01 AM »
Hi all,
I am now at the part of making the pistons for TICH's cylinders and wanted to know how I should machine it to get it to fit. I bought some LG2 gunmetal rods yesterday and I don't know how to make a piston the right fit.
The pistons will have graphite yarn around them , so how should I mae them to fit?
Any help would be appriciated :)
Kind regards
Marinus Kruger
Offline tel
  • Bathurst District, NSW, Oz.
Re: Pistons
« Reply #1 on: October 23, 2013, 11:34:06 AM »
Pistons are best roughed out something over sized, then mounted on there piston rods (held in a collet for preference) for final turning. Just keep taking VERY fine cuts and use the cylinder as a gauge. You do have a little leeway on the fit since you are using graphite packing - a couple of thou undersize won't matter much.
Re: Pistons
« Reply #2 on: October 23, 2013, 11:35:50 AM »
Wot Tel said!
Re: Pistons
« Reply #3 on: October 23, 2013, 12:18:27 PM »
Marinus, I am assuming you have the cylinders bored/honed/lapped to their finished size...else your efforts may be in vain.
Offline Marinus
Re: Pistons
« Reply #4 on: October 23, 2013, 02:45:09 PM »
Thank you all for the reply. That helped alot, thanks Tel :D
Bill.. yes it is honed to final size ;D
Kind regards
Marinus Kruger
Offline Stuart
  • Tilchestune UK
Re: Pistons
« Reply #5 on: October 23, 2013, 02:54:34 PM »
for a loco make the 0.001 inch smaller that the bore when using soft packing  a couple of thou for CI rings in CI cylinders
if you make them to good it will bind up when it get hot , its the packing coupled with the steam oil that give you the seal
to coin a phrase for our lady doctor Steam engine need to be knackered to run not really but they do need a bit of clearance
Offline Marinus
Re: Pistons
« Reply #6 on: October 24, 2013, 05:38:14 AM »
Thank you for teh reply Stuart. Now I am convident that I can make a piston ;D
Kind regards
Marinus Kruger
Offline Steam Haulage
  • Notts UK
Re: Pistons
« Reply #7 on: October 24, 2013, 07:58:18 AM »
"Steam engine need to be knackered to run" !!
Don't let anyone from Swindon hear you say that. It's a good job Wiltshire is a fair distance from Derbyshire.
JerryNotts
Dogs look up to you, cats look down on you, pigs treat you as equal.
Re: Pistons
« Reply #8 on: October 24, 2013, 09:03:07 AM »
Best qualify this by bore sizing........0.001"/inch is realistic for model engines from say 0.5" to 3" bore .......from there upwards the clearance should diminish  :hammerbash: ...Derek
Offline Stuart
  • Tilchestune UK
Re: Pistons
« Reply #9 on: October 24, 2013, 09:55:00 AM »
Derek
A the OP said he was building a tich loco so as not to complicate the issue I quoted the fit to suit his build
Offline tel
Re: Pistons
« Reply #10 on: October 24, 2013, 10:06:40 AM »
13/16" bore from memory.  :old:
Re: Pistons
« Reply #11 on: October 25, 2013, 05:11:31 AM »
Stuart....with my age ....I was trained  :happyreader: with Christian units of measurement  ...being " & parts there of  :LittleDevil:.......
It was not my intention to quote song & verse from BS.1916 Part 1 "Limits of Fits"........just to offer a humble clearance concept of 0.001"/inch is realistic for model engines
Further to this I do not believe BS.1916 Part 1 "Limits of Fits"........should be referenced by younger [inexperienced] engineers as the Standard does not consider any  :Mad: temperature gradient .....Derek
Offline Marinus
Re: Pistons
« Reply #12 on: October 25, 2013, 06:19:05 AM »
11/16" bore Tel ;D
I will make the pistons 0.02mm/0.001" smaller to fit.
Kind regards
Marinus Kruger
Offline tel
Re: Pistons
« Reply #13 on: October 25, 2013, 08:34:07 AM »
The best test of piston fit is to either block one end with your thumb, hold vertically and with the piston/rod inserted it should not sink down into the bore until you remove said thumb. Then a little 'suck and blow' test - DO NOT INSERT THE PISTON ROD END IN YOUR MOUTH for this one! A gentle sucking and blowing should see the piston moving back and forth.
Offline Marinus
Re: Pistons
« Reply #14 on: October 25, 2013, 10:40:10 AM »
Tell, is that with the packing or without?
Kind regards
Marinus Kruger
