Author Topic: Fowler BB1 in 2"  (Read 112278 times)
Re: Fowler BB1 in 2"
« Reply #120 on: March 26, 2014, 09:37:22 AM »
There is already a recess in the outer hub plate for the hub cap (1.2mm) and the retaining collar (3.2mm), leaving the rest of the 6.35mm as bearing surface.
« Reply #121 on: March 28, 2014, 05:08:44 PM »
I needed to cut the angles at 30 degrees, thankfully I had a square of the right angle:
I also picked up a new toy  :naughty: which enabled me to check the angle once it was set up in the vice.
Then came lots of milling, which one bit is like another :shrug: The only possible interesting bit was the use of a large milling cutter which had had its corners rounded over to form the curve on the backs of the flange. So a large amount of swarf later and it is time to fit the hubs to the beam:
But not tomorrow as I am being taken out  ;D
« Reply #122 on: March 28, 2014, 07:07:53 PM »
Is it my eyes or does the central section look too long. I recon that on yours the perch plates should be 20" long which equates to 3.33" or 85mm on the model and they extend to just beyond where the axle thins down which you have at 117mm? The pdf you sent me looks shorter than the metal??
EDIT just measured your drawing and the middle should be 89mm long not 117 >:(
I did the same on mine made it to Hainings widths then had to machine about 3/4" off each side.
Bring it tomorrow and I'll bring mine
« Last Edit: March 28, 2014, 07:25:34 PM by Jasonb »
« Reply #123 on: March 28, 2014, 07:26:14 PM »
Just checked  :wallbang:  :wallbang: That was version 1 of the drawing I machined to. At least I still need to take metal off  :naughty: rather than try sticking it back on  :hellno:
If you want to see my bits you will have to come to the house  :mischief:
« Reply #124 on: March 28, 2014, 07:30:41 PM »
I just came to teh same conclusion while you were typing that, its the one you drew in Augest thats correct not the previous February. At least you could round the internal corners now :ThumbsUp: its only a quick Rotary table job to make the perch plates match.
Just your beam will do
« Reply #125 on: March 29, 2014, 08:47:48 PM »
We had a look at the beam problem, the concern is that, yes the original was forged hence the curves but if the replacement starts using curves and the perch pads curves are not exact  :hellno: that there is a high probability of a dirt gap between that and the perch plate  which will cause rust  :o and the curve is only visible for 6.35mm of its height hidden down a gap between the two tool boxes  :thinking:
Still trying to decide if the rust pocket risk is too high :headscratch:
« Reply #126 on: March 30, 2014, 08:25:33 AM »
They were never a good fit on the originals so if you create a rust trap you have done a proper job and got it just like the original.
Also if you don't round off at least the external corners of the axle then you will also have to have angular corners on the perch plates to keep a similar thickness upstand. Seems a shame to go to the trouble of redesigning every part of this engine to be like the original and then skimp on these parts just to make it easier to machine the top & bottom perch plates.
« Reply #127 on: March 30, 2014, 06:45:20 PM »
 :toilet_claw: I got the original BB1 drawings out and put my beam alongside and found  :o it was too long.
Now the Hanning drawings that I started with are  :-\  :facepalm2:  :Doh: at times and I had forgotten that he had drawn the leading wheel built with the rims central on the hubs  :ShakeHead: As you can see from the drawing they are offset by 6.35mm. But more than that the entire beam is over length  :hellno: by 25mm  :( So my nice flanges will have to be turned off  :'(
I did have a little play with the curves in the centre. Not a nice thing to machine those curves it scaled down to needing a 34mm cutter and thankfully yesterday someone polished the last remains of the moths out of my purse by selling me this rather nice shell mill arbour which I just happened to have a 35mm shell for :naughty:
I lined the cutter up with the line using a square, zeroed the DRO and then slowly proceeded to mill first the wrong side (climb milling  :Doh:) then the right of each end of the beam. That wrong side was  :o the cutter wanted to catch  :disappointed: I am now going to have to go and watch the race to charm my nerves before I decide how to proceed.
« Reply #128 on: March 30, 2014, 06:58:10 PM »
That looks better already, just as well I told you to look at that drawing.
You may also want to revisit your front spoke drawings and wheel assembly as your front wheels don't have any offset
PS do you want to know who won the race?  :mischief:
PPS there is a programme on BBC 4 at 7.00 pm all about old british motor bikes, another of your passions
« Reply #129 on: March 30, 2014, 07:02:58 PM »
I have every confidence it was a handsome man driving a  :Love: car who is too young for me  :-\
« Reply #130 on: March 30, 2014, 07:09:07 PM »
I think he is taken, but you can always dream :lolb:
Offline Johnmcc69
  • Erie Pa., USA
« Reply #131 on: March 30, 2014, 07:23:00 PM »
Hello Jo, where can plans for this engine be found?
You're doing a fine job.....
« Reply #132 on: March 30, 2014, 07:33:27 PM »
Tyler Steam do the drawings but they will give you a "stand off scale" model and will need a lot of extra work to get a true representation which is what Jo has done.
http://darbysavage.blogspot.co.uk/p/fowler-bb1-ploughing-engine.html
The old copies of Model Engineer that covered the build of this engine also have the drawings
I have heard they are not teh best at customer service and would not like to use some of teh castings that they are now offering in aluminium when the patterns were probably designed for iron which is a more suitable material.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #133 on: March 30, 2014, 07:46:50 PM »
Thank you Jason. I would love to see the CAD models the both of you have recreated!
It's quite the project just doing that part of it.
 Who won the race? I won't tell Jo...  :stickpoke:
« Reply #134 on: March 30, 2014, 08:01:37 PM »
The article in Model Engineer does not contain the Hanning Drawings  :disappointed:
And whilst I have an original set of blue prints, Tyler is now providing photocopies of these original drawings and I have been told they are very difficult to make out >:(
