There were less than 500 of these engines ever built (100 made in the UK by the Reading Iron Works).
What is fascinating is that it is double acting, with flat slide valves, parallel to and on opposite sides of the horizontal cylinder, so much like a Corliss you get separately performed intake and exhaust functions. The flyball governor is controlling the gas valve. The cylinder is 5.5" in diameter, 8.5" stroke and watercooled.
Sadly it had a "exceedingly delicate and troublesome" electric ignition system which consisted of two Bunsen-cell batteries, a Ruhmkorff induction coil, a distributor and a sparkplug in each cylinder head. The adjustable vibrating contact in the primary circuit of the coil induces high tension sparks (100 to 150 per second) across the plug gap in the secondary.
The distributor is a insulated disc fastened to the end of the crankshaft.
There is a second owned by the science museum in London which was built a few years after the one in Paris. It is a pretty little thing
but has an ignition as reliable as my R&B
