Author Topic: Gold Blend. Dark Roast........  (Read 9687 times)
Offline Stilldrillin
« on: September 18, 2013, 11:01:38 AM »
This is my, "Gold Blend" engine. During construction...........
 At the recent show. Running very well, as usual.   :ThumbsUp:
Towards the end of the day, I went for a walk round, to see the other tables. About 1/4 hour.  :)
When I returned, black smuts were coming from the firebox. And it was blummin HOT!!!  :o
The twin, beeswax candles, had spontaneously combusted........
Balsa wood doesn't like high temperatures.........
The outside of the cap had a thick coating of soot. And, some pretty colours inside........
And a sticky, smelly deposit on the piston and displacer rod. Action jammed.......
Time for another rebuild!  :facepalm2:
Sigh.......
David D
David.
Re: Gold Blend. Dark Roast........
« Reply #1 on: September 18, 2013, 11:15:47 AM »
Yep...I would say she got hot alright!!  Doesn't look like any damage that can't be fixed though...and a very nice looking engine too David!! When you get it back in ship shape, I would enjoy seeing a video of it running if possible.
Online steamer
« Reply #2 on: September 18, 2013, 11:28:19 AM »
The damage seems very minor ....I'm sure you can sort it!... :ThumbsUp:
« Reply #3 on: September 18, 2013, 11:34:00 AM »
Bill, Dave.
Thanks for your comments!
Nothing that can't be fixed.......  ;)
Here's the build story, and videos. If you have the time...... http://madmodder.net/index.php/topic,5732.0.html
David D
David.
« Reply #4 on: October 15, 2013, 07:18:02 AM »
Hmmm...... Almost a month gone, already!  :o
Not had much workshop time, recently. Just a few minutes, here and there......  :shrug:
I made up a bundle of offcuts, to give a 4" square cube.........
And started to turn it into a former, for the new displacer. Messy stuff.........
Finished article.........
Wrapped tinplate around, and soldered the overlap..........
Two off, 3mm thick end discs. Thinned to 1mm, where possible........
The wooden former, held the disc square to the tube, while I drilled for 6off 1.5mm dia rivets
Natural ingredients only, for my engines.......
Then rolled the tin over the end cap, and tidied up with a gentle touch on the grinder.........
Internal boss for the 4mm threaded displacer shaft.......
Held with 2off M2 grubscrews, and hi temp sleevelock........
The assembly spins true, within half a mm. Close enough........
Initial runs, on twin candles were disappointing.
The hollow displacer sounds to be grinding/ grating as it slides through it's bush. Quite noisy!
Not a coffee table engine any more!
The new displacer weighs 94grms. The original one weighed 69gms, after toasting. The extra weight caused a hesitation, getting over TDC.
So I added 3 extra,  2" x 1/2" x 1/8" weights to the flywheel........
Didn't make any difference!
So, I tried with my temporary meths burner, and it ran happily. Well balanced, even up to blurred revs.  :ThumbsUp:
I feel another, stainless burner coming on.......  ;)
David D
David.
Offline jwcnc1911
« Reply #5 on: October 15, 2013, 01:52:44 PM »
Tht's got to be the best looking "can" Stirling I've ever seeen.  Nice work on that thin metal there.
That thing looks huge, what's the bore/stroke?
JW
« Reply #6 on: October 15, 2013, 02:35:07 PM »
I agree with JW...well done on the new displacer too!!  Looking forward to seeing it running as well.
Offline V 45
  • central PA...USA
« Reply #7 on: October 15, 2013, 03:02:35 PM »
I simply love Trecle !! Is that how it’s spelled ? Never called it anything else. I grew up with the stuff, but haven’t had any in years. I haven’t been able to find any in the states. While I was deployed overseas I ran into some British soldiers and asked them if they had any Trecle….they all laughed at me for asking that way and said I must be really old to call it that !! I'm not that old !! But in the end I had acquired a big tin of the deliciousness. I reminded me of home while I was in a very hostile environment !! It was very soothing at the time and place to have some home comfort reminders. Anyway…just thought I would pass that along…..good use of the tin !!
fcheslop
« Reply #8 on: October 15, 2013, 04:38:53 PM »
Aye up David, its grand ta see t engine coming back together glad youve managed un shop tahm :ThumbsUp:
cheers
Offline smfr
« Reply #9 on: October 15, 2013, 04:46:56 PM »
It's good stuff, that treacle! My wife orders it through Amazon :)
Simon
Offline V 45
  • central PA...USA
« Reply #10 on: October 15, 2013, 07:10:41 PM »
Simon
[/quote]
 Cool...Thanx Simon ... will have to look for it again !!
« Reply #11 on: October 15, 2013, 07:53:51 PM »
JW, Bill.
Thanks for your comments! :cheers:
Displacer bore is 3 3/4", power piston 11/16", both strokes 1".
There will be a final video. Eventually.  :ThumbsUp:
Work to do on firebox, and new meths burner. Shop time is limited, unfortunately......  :(
David D
David.
« Reply #12 on: October 15, 2013, 08:03:28 PM »
Dave V45.
I too have enjoyed treacle ("treekl"), over the past 70 yrs. Never did/ do call it by it's correct title!  :LickLips:
Use it in my morning porridge. Also, I use it in the flapjacks I bake, for my other forum's members........
Never forgetting to finger clean out the residue, before washing and storing the empty tin.   :P
David D
« Last Edit: October 15, 2013, 08:13:11 PM by Stilldrillin »
David.
« Reply #13 on: October 15, 2013, 08:16:11 PM »
cheers
Heyup Frazer.
Seems I need to teach you to speak proper Derbyshire. Ma Duck!  ;)
Thanks Marra!  :ThumbsUp:
David D
David.
fcheslop
« Reply #14 on: October 15, 2013, 09:16:42 PM »
 :Jester: Im all ears marra
Im only a begginer  ma duck
Those flap  jacks look canny
cheers
