but I'm still kicking myself over the bearing!
Luckily I was able to knock the broken end out of the part from the other side. I obviously wasn't doing it right, but what's the right way to use a taper pin reamer? It seems like it's going to be cutting along its whole length once the hole steps are taken off, which, for an HSS tool less than 1/8" in diameter, seems like a lot of cutting pressure.
What end of the pin did you mill down? Just the one opposite the end you peened? Or both? (Cause I'm wondering why you peened.)
BTW, what do you use for a heat source for your silver soldering? What kind of torch do you have?
