Author Topic: Scratch built giant rc car  (Read 14574 times)
Offline KB
« on: September 11, 2013, 03:51:07 AM »
I haven't built any model engines lately, but I have done a bit of model engineering.
Rear differential and drive-train;
Servo saver and steering linkage;
Shocks,
Various parts;
Coping a tube in the lathe;
Hopefully, one day, it will all come together to look something like this;
Have fun out there!
-Kevin
Offline metalmad
Re: Scratch built giant rc car
« Reply #1 on: September 11, 2013, 04:18:49 AM »
Wow, How nice is that
Love it  :praise2: :praise2:
Offline swilliams
  • Canberra Australia
« Reply #2 on: September 11, 2013, 06:38:09 AM »
Innovative and cool  :ThumbsUp: :ThumbsUp: :ThumbsUp:
« Reply #3 on: September 11, 2013, 11:04:54 AM »
Wow Kevin!    What is powering that beast?......looks like a quad bike engine and transmission! :o
Offline MuellerNick
  • Germany // Outback of Munich
    • Motor-Manufaktur
« Reply #4 on: September 11, 2013, 11:48:23 AM »
Looks like a Honda Monkey (or SS 50) knock-off engine (available with more than just 50 ccm). Cheaply available from China.
Parts look very professional made!
Nick
Online b.lindsey
« Reply #5 on: September 11, 2013, 12:15:01 PM »
That is really some amazing work there Kevin. Beautifully machined parts too!!
Offline V 45
  • central PA...USA
« Reply #6 on: September 11, 2013, 12:41:34 PM »
Again Kevein....GREAT WORK !! That will be pretty cool for your son to crash  :naughty: !! But by the looks of the construction he'll have a hard time doing it !!
Offline KB
« Reply #7 on: September 11, 2013, 05:00:34 PM »
Thanks a lot everyone.
Yes it is a Honda clone. I believe Honda started producing these engines when they came out with the Cub or Passport. The most produced motorcycle scooter in history.
The one I have is a 70cc, 3speed auto. It came from a Chinese quad I was given. It needs a complete rebuild. (think disposable engines) I think up to 110cc uses the same crank-case.
I put a real Honda, 70cc, 3 speed, manual in this contraption;
I'm not too worried about the car, but whatever gets hit! I'm going to try and set-up a triple redundant fail-safe/ kill switch system. 2 electronic and one mechanical.
I should probably take out an insurance policy too. It will be about 4 feet long and weigh well over a hundred pounds.
Cheers!
« Reply #8 on: September 11, 2013, 06:57:41 PM »
Looks great Kevin. I love the "huge" RC stuff. Aircraft with 8' wing span and this kind of stuff.  Dave, this thread may need to be off limits to William. I'm waiting on a Wallaby 8)
Whiskey
Offline smfr
« Reply #9 on: September 11, 2013, 07:41:06 PM »
Wow, awesome stuff!
The front end looks a bit fragile. Any reason there aren't struts across the very front of the frame? Or did you just slice off the front for the rendering?
Simon
Offline jwcnc1911
« Reply #10 on: September 11, 2013, 09:42:50 PM »
This is freakin awesome!
JW
Offline KB
« Reply #11 on: September 12, 2013, 04:59:01 PM »
Thanks all,
Simon, You are right, there will be cross bracing up front and a bumper of some sort. I just didn't work it all out ahead of time. I want to make sure I am happy with the steering linkage before I fill it in.
Also I may need room for a battery and electronics, maybe the fuel tank as well...
I made full size templates for bending.
First set my very expensive angle o' meter;
Then set the starting point of the bend. A sample bend is marked to a corresponding mark on the benders' die. It is placed so that the bend touches the outside of the bend and the mark is transferred to the template;
Then the mark is transferred to the stock;
Then into the bender and bent to the previously set angle;
Then it is notched and back to the template to be marked for final trimming;
I don't have a proper bender, but your standard import bender for which I have made quite a few dies.
For pieces too large to fit the lathe I have this tube notcher, which I made a long time ago;
Cheers,
KB
Offline KB
« Reply #12 on: February 27, 2018, 04:08:47 PM »
Well this project was shelved while I raised my two sons, racing BMX with them and doing a lot of home renovations.
It is time to get back out in the shop!
Online Vixen
« Reply #13 on: February 27, 2018, 04:30:48 PM »
Hi KevinB
That's an amazing vehicle. A full size racer, but in miniature.
I watched the video and have a question about that steering servo. It looks like you are using a window winder motor with a slave servo to give position feedback. Am I correct? The next question is about what are you using for the electronics module. Who is the manufacturer ans supplier?
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #14 on: February 27, 2018, 04:39:40 PM »
If you're going to run it off-road won't you need a lock for that diff?
AS
