Author Topic: A portable steam engine  (Read 87493 times)
Offline Johnmcc69
  • Erie Pa., USA
Re: A portable steam engine
« Reply #30 on: September 10, 2012, 03:36:12 AM »
Cool project Rich. I'm making notes to myself about some of the techniques used here.
I love your tailstock DRO, thats slick.
Offline Firebird
  • East Midlands UK
« Reply #31 on: September 10, 2012, 07:43:16 PM »
Hi
Thanks guys.
The tail stock DRO stems from a good while back when I only had the one digital calipre. Its designed to simply clamp in when needed without any mods to the calipre.
Dave, the press can be seen here
http://www.modelenginemaker.com/index.php/topic,275.0.html
Rich
Offline Firebird
  • East Midlands UK
« Reply #32 on: September 13, 2012, 07:49:05 PM »
Hi
Just had time tonight to do a bit of silver soldering. First of all I put a few light centre punch marks on the valve chest to give a thou or two clearance between the parts. The machined recess was supposed to be for a spigot on the gland body to sit in but a change of plan did away with it.
After a coating of flux the gland body is placed in position using a short length of 1/8 stainless steel rod to line it up.
Then clamped.
Set up in the brazing hearth. You can just see 2 pieces of silver solder in place each side of the gland.
And finally the guide pin is pulled out
after silver soldering
It seems to have gone ok. Its in the pickle now for a clean up.
Rich
Offline NickG
« Reply #33 on: September 13, 2012, 08:58:09 PM »
Looks spot on that silver soldering Rich  :ThumbsUp:
One question though, was there any particular reason you didn't turn the gland as part of the whole thing as you did the spiggot on the other end?
Cheer,
Nick
Offline Firebird
  • East Midlands UK
« Reply #34 on: September 13, 2012, 10:48:38 PM »
Hi Nick
Not enough forward planning I'm afraid. I was going to drill and tap the end of the steam chest and screw a gland in but because of the mods to accomodate the slide valve not enough material remained to do that (I still have to file some notches in the steam chest ends to clear the valve rod locking nuts). I have to thank Sandy C for coming up with this idea to save the day. I didn't fancy having to remake the steam chest as I doubted I could get all the stud holes to line up with the tapped holes in the cylinder. I'm making this up as I go along so I have to adapt here and there. I'm sure there will be more occasions where I have to adapt as well. If I make another of this type of engine I would include the gland as part of the steam chest. You live and learn but its all great fun.
Rich
« Reply #35 on: September 13, 2012, 11:49:36 PM »
No doubt it will go well though.
Always nice work.
Offline Firebird
  • East Midlands UK
« Reply #36 on: September 14, 2012, 08:18:00 PM »
Hi
Thanks Carl
After a clean up a trial assembly
Rich
Offline smfr
« Reply #37 on: September 14, 2012, 09:34:32 PM »
That's looking really good!
Offline doubletop
  • Wellington NZ
« Reply #38 on: September 14, 2012, 10:36:20 PM »
Rich
That's looking very nice.
I was a bit worried about the sacrificial engineers clamp, they're never the same after a bit of heat. I wasn't happy with myself after I'd ruined one doing the same thing.
Online steamer
« Reply #39 on: September 14, 2012, 11:56:21 PM »
Ditto!   but your stuff always looks great Rich!
 :NotWorthy: :NotWorthy: :NotWorthy: :NotWorthy:
Offline NickG
« Reply #40 on: September 15, 2012, 11:28:41 AM »
Looks extremely neat Rich. Very nice.
Offline Firebird
  • East Midlands UK
« Reply #41 on: September 15, 2012, 12:35:49 PM »
Hi
Thanks guys.
The clamps were a real bargain, a set of 4 for ?10.00. I got them at a steam fair. I only use this set on the brazing hearth, they were so cheap I don't mind if they are sacrificial.
Rich
« Reply #42 on: September 15, 2012, 01:25:35 PM »
Its comming along well Rich.
Are you going to bring the exhaust out the top or drill a passage in from the front to meet the hole you have on the top of the cylinder then plug that hole?  As the exhaust really wants to run below the crank and into the chimney base to get the blast pipe in the right place.
Offline Firebird
  • East Midlands UK
« Reply #43 on: September 15, 2012, 08:37:47 PM »
Hi Jason
The pipe has to come out the top. I did look at ways of getting it out the front but there is either an inlet port, which is drilled at angle from the cylinder end, or a valve chest stud hole in the way. Although the brake cylinder is a good start and machines well I have to make some compromises with it. I will probably make an outlet connection along the lines of the inlet on the valve chest cover to keep the exhaust pipe as close to the cylinder as possible.
Rich
Offline swilliams
  • Canberra Australia
« Reply #44 on: September 16, 2012, 01:36:43 AM »
Looking really good Rich
