Author Topic: A portable steam engine  (Read 87809 times)
Re: A portable steam engine
« Reply #165 on: July 21, 2015, 08:27:14 PM »
Good progress and a good save  :ThumbsUp:  :ThumbsUp:
Offline Firebird
  • East Midlands UK
« Reply #166 on: July 25, 2015, 08:12:15 PM »
Hi
Thanks Roger.
I needed a couple of bolts for the eccentric so today I made a couple. Start with 2 studs made from 3/32 stainless steel.
Screw on 2 steel nuts
Silver solder
Clean up
Fitted in the eccentric. I will fit locking half nuts on final assembly
Moving on to the piston. About 6 months ago I bought a piece of cast iron bar to make the piston. Could I find it.  :shrug: :noidea: :thinking: :old: yes after about 2 hours of searching, what a waste of a rare saturday afternoon in the workshop :censored:
The piston rod is 5/32 stainless steel.
The elusive cast iron turned to size and drilled and tapped
The piston rod is held in the tail stock chuck to ensure correct alignment. A drop of loctite on the thread and the 2 parts screwed together.
Cut a ring groove and part off
Face and size the piston
Rich
Offline Firebird
  • East Midlands UK
« Reply #167 on: July 27, 2015, 07:54:48 PM »
Hi
My plan is to get the engine to run on air. Once I know it will run I can can get on with the boiler. I have started to assemble the engine, if it does run I will strip it down again to finish off all the cosmetic bits and polish it.
Here's some of the parts. The cylinder block has had the studs fitted.
The slide valve and the slide valve housing fitted.
The slide valve gland is packed with carbon string.
The cylinder covers, piston and connecting rod in place
Rich
Offline Stilldrillin
« Reply #168 on: July 27, 2015, 10:49:30 PM »
Rich.
It's all looking good, and taking shape nicely.......
David D
David.
« Reply #169 on: July 28, 2015, 12:46:59 AM »
That is looking amazing Rich. I have been following along just haven't been commenting much. Very nicely done!!
« Reply #170 on: July 28, 2015, 01:24:39 AM »
Same here Rich and some impressive work your doing.
Offline Firebird
  • East Midlands UK
« Reply #171 on: August 01, 2015, 10:13:39 PM »
Hi
Thanks David Bill and Don.
Well what do you know, it runs :wine1: :cheers: :DrinkPint:
<a href="https://www.youtube.com/watch?v=WQrsK5ileKU" target="_blank">http://www.youtube.com/watch?v=WQrsK5ileKU</a>
Rich
« Reply #172 on: August 02, 2015, 02:05:32 AM »
Cool Rich I love it!   8)
Offline Kim
« Reply #173 on: August 02, 2015, 03:00:50 AM »
It runs!  Congratulations Rich!  :ThumbsUp:
« Reply #174 on: August 02, 2015, 07:24:10 AM »
Very nice  :praise2:  :praise2:
« Reply #175 on: August 02, 2015, 07:52:48 AM »
 8) Don't you love it when they come to life   :cartwheel:
Offline ths
« Reply #176 on: August 02, 2015, 09:04:11 AM »
Well done Rich, ticks over very nicely indeed. Cheers, Hugh.
Offline NickG
« Reply #177 on: August 02, 2015, 01:14:55 PM »
Nice 1 Rich, looking brilliant!
« Reply #178 on: August 02, 2015, 01:38:23 PM »
Congratulations Rich!! Runs as good as it looks...well done!
« Reply #179 on: August 02, 2015, 04:21:28 PM »
Nicely done Rich!
Congrats!
Database Error
Back
