Author Topic: A Wallaby of my own.  (Read 256527 times)
Re: A Wallaby of my own.
« Reply #30 on: July 30, 2012, 01:33:44 AM »
OK, Finally felt good enough to get out in the shop for a couple of hours.  I got the shafts for the oil pump done tonight, and made a bushing to locate the bearing holes in the cover, and put in the bearing holes with the bushing and a D-bit.
Turns nice now.   I need to tap the inlet and outlet.  The plans call for #10-40, and I'll probably use that size thread for the spark plugs so I'll get that tap and die and add it to my collection.
No real drama, other than I need more light in the shop.   The eyes aren't what they used to be! :hellno:
Offline Doc
  • USA ND
« Reply #31 on: July 30, 2012, 03:25:43 AM »
I know what you mean about the eyes not being what they use to be I suffer from that also. You oil pump looks nice and you have done some nice work. Looks like an interesting engine we will be watching.
« Reply #32 on: July 30, 2012, 03:29:38 AM »
I know what you mean. When I first read that, I read "more light in the soup".
It's worse with the hearing. Sometimes what I hear is funny...sometimes she gets upset.
Offline Doc
  • USA ND
« Reply #33 on: July 30, 2012, 03:39:55 AM »
Phhahahahahah I think I suffer from that very same thing!!!  :cheers:
« Reply #34 on: July 31, 2012, 09:18:15 AM »
My wife sent me to get my hearing tested!   I went through the battery of tests at a very prestiqeous medical center...and the doctor said I have good news and bad news
The good news is you have a little bit of mid range loss in your left ear...but not enough to worry about and otherwise your hearing is normal.
The Bad news is your hearing is normal !   ...... :Lol:      He was right!,,,,,that was bad news!
« Reply #35 on: July 31, 2012, 09:20:17 AM »
Ordered 10-40 tap and die yesterday... I'll need make a co-bore tool to make a square bottom hole and to spot face the outside surface for a seal washer.
Offline ironman123
« Reply #36 on: August 01, 2012, 04:31:57 AM »
You got it going on there Dave.  Watching this Wallaby.
Ray
Ray
Central Texas
« Reply #37 on: August 01, 2012, 05:51:41 PM »
Thanks Ray,   The way this week is going, I'll probably update on the weekend.....I work too much!
« Reply #38 on: August 05, 2012, 03:20:51 PM »
Ok
I got up early this morning and got to work on the oil pump.
I was able to tap 10-40 using a .156 diameter as a tap drill, even though, the book says it should be .166.
This let me make the hole with an end mill (5/32) and spot face the hole (.25").
I had to deburr the part a bit, but it went back together....I need to shorten the screws....but I'll post a finished photo in a bit.....got the lawn to mow first ::)
« Last Edit: August 05, 2012, 04:45:04 PM by steamer »
« Reply #39 on: August 05, 2012, 05:36:48 PM »
OK question to the membership
I don't really want to use a "point" ignition and would prefer an electronic ignition.
Whose should I use?
I can run a two magnet rotor off the camshaft and go from there or use a loss fire system.
Remember you have a Mechanical guy messing with wires......never really a good thing! :slap:
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #40 on: August 05, 2012, 06:04:55 PM »
I would go with Roy. He is a great guy to work with and if you need help he works hard to make sure everything works great. He is at the model shows every year.
I have had the basic ignition in the Peewee for about 3 or 4 years now and everything still works great. I did burn out a sensor when I was doing the inital shake down but now that the ignition timing is set and everything is dialed in, the sensors last for years.
http://www.cncengines.com/
« Reply #41 on: August 05, 2012, 06:16:40 PM »
Thanks for that Steve!
I think I'll just use 2 magnets off the cam and keep the ignition box seperate from everything else.   I can shield it easier I think if I ever decide to put this little beasty in a R/C tug of something....
« Reply #42 on: August 05, 2012, 06:25:39 PM »
The original plans call for a 3/8 plug!   I think I want to use a 10-40  or 1/4-32 plug instead.
Considering the head will be aluminum....I'm thinking maybe 1/4-32 would be a better idea as I think the threads will hold up better...though they're still kinda big...
I think you gave me some advice on this long ago Steve.....so excuse me for asking again.
« Reply #43 on: August 06, 2012, 01:43:33 AM »
Alright
Oil pump is complete!   ON to the gears!
Damn hot here.....was near 100F yesterday...and 90 plus today...makes the shop pretty miserable....
Offline Captain Jerry
  • Summerfield, FL USA
« Reply #44 on: August 06, 2012, 07:03:25 AM »
Don't worry Dave.  It's a common affliction.  As women get older, they begin to mumble.
Jerry
NOTARY SOJAK
