Author Topic: A Wallaby of my own.  (Read 255854 times)
Re: A Wallaby of my own.
« Reply #975 on: January 09, 2019, 02:24:37 AM »
Dave,
Take care of yourself. My wife picked up some bug, I seem to have caught the tame version of it. Your progress looks good. So does the dipstick itself thread into the case?
« Reply #976 on: January 09, 2019, 08:37:45 AM »
Yes   the print calls for 1/2-26    but im using 1/2-20
« Reply #977 on: January 12, 2019, 01:07:37 AM »
OK got the 1/2-20 thread cut....not without drama on the tap...see notes elsewhere.
The new Nikcole insert worked a treat single pointing the threaded cap.    drill some holes and make a gasket and done and dusted....we'll see how much time I get this weekend.
« Reply #978 on: January 12, 2019, 01:39:03 AM »
Hi Dave
Just getting caught up on this project.  All looks good from where I sit.
Had my cold just before Christmas.  Slight fever and chills for about a day, then feeling like crap for a few days more; but it all passed quickly before the dreaded bronchitis set in.  Take care of yourself.
Offline 90LX_Notch
    • YouTube Channel
« Reply #979 on: January 12, 2019, 02:42:54 AM »
It's coming along nicely Dave.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #980 on: January 13, 2019, 05:40:59 PM »
I have a knee up on my mill today...so I just might as well use it....but ive been dreading this operation for some time.......
35 degree angle through the center main, the web and out the center of the throw...nothing but net....x2.....
 :zap:
Wish me luck as I face my demons!
Online Vixen
« Reply #981 on: January 13, 2019, 06:18:07 PM »
I hope you are going to start the cross drilling by using a center cutting end mill. It will not get pulled to the side as will happen if you try to start the drilling with a standard center drill.
Good luck
« Reply #982 on: January 13, 2019, 06:21:48 PM »
Good luck
Abso-freakin-blutely!     I'm gathering the tooling in one place....looking for a good 0.078" long series drill   I'll start with a 3/32 end mill short series end mill.... :paranoia: :ShakeHead: :toilet_claw:
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #983 on: January 13, 2019, 07:32:20 PM »
Just be careful when you break through the bottom. Thats when the drills tend to break.
Good news! I have finished a prototype 10-40 plug. All the tooling is done, all the fixtures are made, and all the Gcode is written. With any luck i'll have 50 in stock by the end of next week.
<a href="https://www.youtube.com/watch?v=W8csFklGOck" target="_blank">http://www.youtube.com/watch?v=W8csFklGOck</a>
« Reply #984 on: January 13, 2019, 07:39:10 PM »
Sounds good Steve!    Got the hole in perfectly on the first side.    Now to ser up the second side
« Reply #985 on: January 13, 2019, 07:48:14 PM »
Nice Job! How was it coming out the bottom? Was the bit a little grabby?
« Reply #986 on: January 13, 2019, 08:02:16 PM »
I was worried about that too, but didn't grab in the least..just popped thru.    Second one went in like the first.  DONE.
Now for the key-way on the gear side.
« Last Edit: January 13, 2019, 08:17:40 PM by steamer »
« Reply #987 on: January 13, 2019, 08:22:50 PM »
Nicely done Dave. The keyway should be easy after that :)
« Reply #988 on: January 13, 2019, 08:26:16 PM »
Thanks for looking in everyone.    Yup...keyway and 8 tapped holes for the counterweights....and done and dusted.
Wait a minute.   The crank pins are hollow...I need to drill them out, and put in plugs...at least on the print I do.
Should be able to do both features with the same set up but with the margin block set to horizontal.   It's already on center.
« Reply #989 on: January 13, 2019, 08:32:17 PM »
That should be interesting.....I think I'll make those plugs loctited in instead of press fit....my nerves are on edge already.
