Author Topic: A Wallaby of my own.  (Read 255615 times)
Re: A Wallaby of my own.
« Reply #915 on: December 31, 2018, 12:51:08 AM »
Cylinders are done.    1.005 and 1.0045.....
Time to finish the pistons.
 :ThumbsUp: :ThumbsUp:
Online steamer
« Reply #916 on: December 31, 2018, 01:00:56 AM »
And some pictures...
Online steamer
« Reply #917 on: December 31, 2018, 01:12:12 AM »
Starting to look like an engine....
« Reply #918 on: December 31, 2018, 01:48:01 AM »
Dave,
Lookin great, definitely looking like an engine.
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #919 on: December 31, 2018, 02:29:43 AM »
Thanks Steve!     How the plug factory coming along?
I have 1/4-32 side fire (Dale Detrich design) $10
8-40 side fire $15
8-40 with conventional ground strap $15
Tomorrow I am going to make Insulators for 10-40's. I started bases but some tooling wont be here until Jan 5th. I would think I will have 10-40 done by the end of Jan. Would be sooner but i have to work every day from the 2nd - 12th.
10-40's will be $15
Online steamer
« Reply #920 on: December 31, 2018, 03:49:55 AM »
Sounds good buddy   let me know when you have them
« Reply #921 on: December 31, 2018, 05:47:51 AM »
Lookin' pretty there, Dave!   :popcorn:
« Reply #922 on: December 31, 2018, 08:11:38 AM »
.....but i have to work every day from the 2nd - 12th.
Sounds horrible  :disappointed:
Online steamer
« Reply #923 on: December 31, 2018, 11:58:52 AM »
Thanks Kim!
« Reply #924 on: December 31, 2018, 01:37:35 PM »
Definitely looking like an engine Dave, and a nice on too!  The new lighting must be making things easier too now that you can see :)
« Reply #925 on: December 31, 2018, 04:28:19 PM »
Enough light is always good.
« Reply #926 on: December 31, 2018, 08:34:08 PM »
No big deal. I only worked 8 days this month.
Online steamer
« Reply #927 on: December 31, 2018, 11:13:39 PM »
It does Bill.   gives you a whole new outlook I'll tell ya!
I finished the liners.   Now on to the pistons.    I parted off the chucking pieces, and made up a Westbury holding fixture which is a turned spigot that fits the piston recess and back face tight and held on with a eye bolt and a temporary wrist pin.    But   before I do that, I need to work up a 0.040" ring grooving tool for the piston rings.   Pictures tomorrow.. i got a lot done today, including the rotary table adapter as well.   I'll take pictures of that and update tomorrow
« Reply #928 on: January 01, 2019, 12:26:30 AM »
Hello Steamer!
I'm not knocking anything but a .040 wide groove seems excessive for the 1 inch bore. Trimble method says a .043 thick ring .022 wide. I'm just wondering if that's what's in the drawings. A .031 inch wide is a pretty standard grooving insert. If you skinny up the ring to .0295 with a .031 groove it might make things a bit easier. With the .043 thickness it should have plenty of wall pressure. Might save you from having to grind a crazy small tool without sacrificing a good ring seal. I honed the pacifier to .750 and put .027's in it and it didn't even smoke after a few minutes of running.
Just trying to help!
Online steamer
« Reply #929 on: January 01, 2019, 01:07:31 AM »
Hey Steve     Westbury wants 0.060 x 0.060.  X2    8)
