Author Topic: A Wallaby of my own.  (Read 256521 times)
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: A Wallaby of my own.
« Reply #660 on: December 04, 2016, 09:43:40 PM »
Sounds like you had a pretty good day but for some reason the pictures aren't showing up :naughty:
« Reply #661 on: December 05, 2016, 04:48:59 AM »
Tomorrow!
« Reply #662 on: December 26, 2016, 08:27:12 PM »
Got the main bearings roughed out.   I'm making them in pairs, so for a 3 main crank, I have 6 identical bearings that I will now machine into halves.   Upper and lower.
I also need to machine the taper on the cam shaft and the crank shaft which means making a reamer.
Pictures to come
« Reply #663 on: December 26, 2016, 08:32:20 PM »
The last Wallaby pics were nearly two months ago  :ShakeHead: We hear the words, but without pics do we believe anything is happening  :hellno:
« Reply #664 on: December 26, 2016, 08:37:24 PM »
Camera broke?  :lolb:
« Reply #665 on: December 26, 2016, 07:50:48 PM »
Lens frozen over, battery dead, William had my camera: just saying  :lolb:
Cletus
« Reply #666 on: December 26, 2016, 10:01:17 PM »
Can't you bore the two tapers and then cut the tapers on the crank and cam shafts at the same topslide settings, they are not that small that you can't get a boring bar inside them?
« Reply #667 on: December 26, 2016, 10:59:01 PM »
Don't have the mating parts ready yet, and I want to cut the taper on the shafts first to position the cam gear.     So....I'll just ream them
« Reply #668 on: December 26, 2016, 11:10:24 PM »
The last Wallaby pics were nearly two months ago   We hear the words, but without pics do we believe anything is happening
WAh Wah Wah!....
« Reply #669 on: December 26, 2016, 11:11:39 PM »
Current state of play.....
Need to cut down the D bit and harden it.
« Reply #670 on: December 27, 2016, 12:09:24 AM »
Hot diggy dog Uncle Jed we got piccys! Looks good Dave but took you long enough to get us some piccys... :stickpoke: just saying......
 :popcornsmall:l
« Reply #671 on: December 27, 2016, 12:14:49 AM »
yeah....well...I have to download them to the computer...reduce the size by 4!   save them and then post.....and I have to email them to myself, as I can't talk to this )@(()*@$( f  phone!!!!.....
Getting there
« Reply #672 on: December 27, 2016, 12:46:41 AM »
Progress now verified :)  Looks great Dave!!
« Reply #673 on: December 27, 2016, 12:51:18 AM »
Good to see progress; looks good Dave!
« Reply #674 on: December 27, 2016, 03:04:46 AM »
I have a water pump that will be driven off the cam shaft at the rear of the engine.   "Howell water pump"    I'll need to put a drive dog in the end of the shaft.
Additionally, I need to hollow out the crank pins, drill the oil passages, and cut a key way on the crankshaft, then that will be done.
After that, I need to make up the cam turning fixture ala Westbury, SteveHuck....ect.
Lots left to do.
« Last Edit: December 27, 2016, 03:08:24 AM by steamer »
