Author Topic: A Wallaby of my own.  (Read 256913 times)
Re: A Wallaby of my own.
« Reply #1095 on: February 03, 2019, 12:09:34 AM »
Don't listen to him Dave. Just another retired guy with too much time on his hands  :ROFL:
It's good that you are getting time back in the shop after that nasty accident last year. Each day you will be able to do a little more than the day before.
Cheers :cheers: :cheers:
http://www.modelenginemaker.com/index.php/topic,7789.msg164803.html#msg164803
Been exactly a year since the surgery to put it all back together!....
Im trying boss!!!  Im trying!     The bearings were a very satisfying job..the first one just slipped together perfectly!....The second, just a touch with a file and it was done.    I'll do bearing shells like that next time for sure....it was really pretty easy...just required some careful work with the holding fixtures...but the F1 was up to it.
« Reply #1096 on: February 03, 2019, 12:24:15 AM »
I was beginning to think we were going to have to have William finish this one  8) :lolb:. Looking good, just KOKO.
Cletus
« Reply #1097 on: February 03, 2019, 12:34:07 AM »
Cletus
No worries brothah.....I'm glad I'm back at it.....but it's a year lost that's for sure!
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #1098 on: February 03, 2019, 12:37:02 AM »
Way to go steamer! You seem to be on a good roll now. Firing on all cylinders as they say.  Haha!
« Reply #1099 on: February 03, 2019, 12:37:59 AM »
Well   7 of them anyway!....
Thanks Steve.....good to be back in the shop!
« Reply #1100 on: February 03, 2019, 12:40:32 AM »
If  you look at the last picture, the core had some taper in it... I'll mill that wall down, but it's at an angle, so I'll need to trig that out and work out the offset and drop for the ball end mill to clean it out
the top side too, which is straight up and down, is a bit close, so I'll trim that too
I'm sure the sump pan is close, but I know it has some meat on it.
The 917 engine will be bar stock....just sayin
« Reply #1101 on: February 05, 2019, 02:42:20 AM »
Slope side cleared out..     offsets like George does it.  Are not that hard.    If you think about it a minute    68 degree slope.  Which amounts to a 2.5 rise to run    so out .02 and then down 0.05.  Cut   repeat.    Worked nice.
« Reply #1102 on: February 05, 2019, 02:48:59 AM »
Nicely done!! Just got to keep your rises and runs unconfused.  :)
« Reply #1103 on: February 05, 2019, 02:58:56 AM »
Its not that bad Bill.  move the Y back 0.020, and raise the knee a full turn.....cut from X = 0 to X =0.687 and return
Repeat
You get into a rhythm, and it's not bad at all.  Pick opportune dimensions....1 turn of the knee is 0.050 for instance...
« Reply #1104 on: February 05, 2019, 03:34:14 AM »
Dave,
At least it aint .080 a turn like the mill at a previous job.
« Reply #1105 on: February 05, 2019, 03:58:40 AM »
Well   with 0.08, you could go 0.032".
« Reply #1106 on: February 05, 2019, 12:31:13 PM »
Now you're talking! Nice job Dave and like you say once you pick up a rythm it goes quite easily.
« Reply #1107 on: February 05, 2019, 12:34:07 PM »
George, Ive been watching you for better part of 10 years...and that's how long it took for me to figure this one out    :facepalm:
Ah well.   I'll get there eventually....thanks for the inspiration my friend!
Online Roger B
« Reply #1108 on: February 07, 2019, 09:52:27 AM »
Looking good  :praise2: The groove in the center main to feed the big ends is now clear to me  :)  :wine1:
« Reply #1109 on: February 07, 2019, 06:12:42 PM »
Thanks for looking in rodger
I cleared the other side of the engine block last night. Pics to come.
