Author Topic: A Wallaby of my own.  (Read 192735 times)
Re: A Wallaby of my own.
« Reply #1080 on: February 01, 2019, 02:07:28 PM »
Want the rotating assmebly done for the NEMES show
« Reply #1081 on: February 01, 2019, 02:41:00 PM »
sounds like an ideal opportunity for a bit of round and round testing  ;)
Usus est optimum magister
« Reply #1082 on: February 01, 2019, 05:41:14 PM »
Pistons going up and down    gears going round and round....thats the goal
« Reply #1083 on: February 02, 2019, 12:45:03 AM »
Dave,
Goals are good. That does look like a lot of swarf for one hole.
« Reply #1084 on: February 02, 2019, 02:03:56 AM »
Split fixture blocked out....need to cut a half round in it now.....tomorrow...
« Reply #1085 on: February 02, 2019, 08:18:36 PM »
Ok   serious progress today.  #2 bearing is pretty tight, so ill need to scrape that one in a little, but the whole process went swimmingly!...ill fit that tight bearing tonight and i can do a rotating assembly check.
« Reply #1086 on: February 02, 2019, 08:22:06 PM »
Looks great Dave!
« Reply #1087 on: February 02, 2019, 08:28:37 PM »
Bearing is fit   had a burr on the side...couple strokes of a file and done.   Just  a bit tight....thatll motor in just fine.
« Reply #1088 on: February 02, 2019, 09:00:38 PM »
Thatís cool Dave they look great!.... :ThumbsUp:
« Reply #1089 on: February 02, 2019, 09:09:57 PM »
Nice work on the bearing. And the rods look great on the crank shaft!  :ThumbsUp: :popcorn:
« Reply #1090 on: February 02, 2019, 09:50:48 PM »
Well done Dave. They look great and sounds like the fit just as well.
« Reply #1091 on: February 02, 2019, 10:40:46 PM »
Thanks for looking in boys....mounted up the crank, and there is some extra metal in the crankcase that needs to come out to let it all rotate....im going to countersink the screws as well.     Tomorrow......
« Reply #1092 on: February 02, 2019, 11:05:06 PM »
I think you should work tonight bud. This started back in 2012 though you are making much better progress now  :lolb:  Just kidding of course.  It's looking great!!
« Reply #1093 on: February 02, 2019, 11:10:26 PM »
Yes it did...there were a few years distraction!
http://www.modelenginemaker.com/index.php/topic,2810.0.html
Online Vixen
« Reply #1094 on: February 02, 2019, 11:13:36 PM »
Don't listen to him Dave. Just another retired guy with too much time on his hands  :ROFL:
It's good that you are getting time back in the shop after that nasty accident last year. Each day you will be able to do a little more than the day before.
Cheers :cheers: :cheers:
