Author Topic: We'll Call it Metisse......  (Read 16538 times)
Offline Ian S C
Re: We'll Call it Metisse......
« Reply #45 on: August 21, 2013, 02:12:23 PM »
Dave, just an idea that may be handy one day. For the burner wick, substitute a bundle of iron/ steel wire, about 24,26 swg is about what I use, you'll never need to replace the wick, unless for some reason it rusts away.  My next one I'm going to try stainless  steel wire.
      I discovered this form of wick in vol 1 Model Engineer and Amateur Electrician  1898.
      Just make the wire full depth of the tank, plus the 1/4" or so of the protruding wick.  Ian S C
Offline Stilldrillin
« Reply #46 on: August 23, 2013, 11:06:56 PM »
Bob, Dave, Don.
Thanks Fellas!  :cheers:
Hugh.
You should see my showtime, blue tartan!  ;)
Ian.
Thanks for the tip!  :ThumbsUp:
I've just been trying pipe cleaners. With some success.
But, I really prefer using stove rope. Several diameters available, at 1 per metre. And, it lasts "for ever".  ^-^
David D
David.
Offline arnoldb
  • Windhoek, Namibia
« Reply #47 on: August 25, 2013, 08:36:02 PM »
Well done David  :ThumbsUp:
Another orphan sorted - shouldn't be long then before we see the next  :stickpoke:  :)
Kind regards, Arnold
fcheslop
« Reply #48 on: August 26, 2013, 08:46:47 PM »
Ah found it :Lol:
 :NotWorthy: :NotWorthy: :NotWorthy: :NotWorthy: :NotWorthy: :NotWorthy:
cheers OH WHAT'S NEXT
« Reply #49 on: August 26, 2013, 10:34:17 PM »
Thanks, Arnold.  :cheers:
Yes. One less, from a long (ish) list.  ^-^
Frazer.
I hadn't hidden it. Honest!  :shrug:
NEXT? NEXT? NEXT? NEXT? Why does everyone want to rush me?  :headscratch:
At the moment, I'm prepping 7 engines, for showing at "Steam Toy Lincs". On 7th September.  :ThumbsUp:
Then, I'll start on modding Mia's engine. Going to make it into a finger/ little fist, engine. For my 3yr old grandaughter.......  :Love:
David D
David.
fcheslop
« Reply #50 on: August 26, 2013, 11:14:56 PM »
Best wishes for STL
Now do you think Mia is going to let grandad loose on her engine :Lol:
cheers
« Reply #51 on: August 27, 2013, 08:26:39 AM »
Best wishes for STL
Thanks Mate!
I've baked 48 flapjacks. Hope that's enough!  :LickLips:
cheers
Mia's not going to know, until it's too late. I hope!  :help:
David D
David.
Offline Ian S C
« Reply #52 on: August 27, 2013, 01:58:13 PM »
David D, I post the bit about wire wicks every so often, because there is on occasions some one asking what to use as a wick.  I'v used bundles of wire from 1/8" dia, to 3/8" dia, and one was 1/8" x 1/2".     Ian S C
Offline Ian S C
« Reply #53 on: September 07, 2013, 01:19:10 PM »
Got a reply from Cornish Jack on the Model Engineer web site, at first he had the piston upside down, sorted that, got it running for a short time, then had a piston failure of some sort, is yet to make a new one.    Ian S C
« Reply #54 on: September 07, 2013, 09:09:28 PM »
Thanks Ian!  :cheers:
I wonder how many first time runners there are, compared to the abandoned failures........  :facepalm:
Mine has just completed it's first show. Around 5hrs running time.  :ThumbsUp:
David D
David.
Offline Ian S C
« Reply #55 on: September 13, 2013, 03:24:32 PM »
David D,  I would imagine that there is less than 50% of kits finished to run, and a lot of those probably very close to working, but given up on, maybe with the builder with a sore wrist from flicking it over.  If you don't get the clearances right it will sometimes go if you persist long enough turning it over, it happened with the first two or three of my motors, my second motor is twenty one this year, at first it struggled to do 200 rpm free, now it can hit 2000 rpm free, the longer you run them the better they go!     Ian S C
