Author Topic: Top Slide Fixed  (Read 2059 times)
Offline Ginger Nut
    • Woolnwood
Top Slide Fixed
« on: July 31, 2013, 07:05:20 AM »
I had to get new topslide T-bolts recently for the ML7 as the 5/16 one was stripped when I bought the lathe but was enough to hold it still. he new ones from RDG tools were 3/8".
I had had trouble pivoting the topslide with the old ones but no way were the 3/8" ones going to allow any movement at all. A check of the slots and I could tell that no casting slag/dags had been removed. I used a a rat tail and 1/2 round file to clean up and square up the slots.
Now I have no problem pivoting.
I am the 4th owner of the ML7 and wonder had those previous owners never had need to pivot at all?
Ray
Offline ths
Re: Top Slide Fixed
« Reply #1 on: July 31, 2013, 10:30:31 AM »
Hi Ray,
I have T nuts holding my ML7 top slide to the cross slide, and I'm pretty sure that they are 1/4 BSF.
I use the top slide swung around all the time, particularly if the tail stock is being used with the dead or revolving centre.
Hugh.
Re: Top Slide Fixed
« Reply #2 on: July 31, 2013, 11:28:37 AM »
They do seem stout!....my 12" 2 HP Logan has (2) 3/8's bolts holding the compound....
If they work...they can't be wrong though!
Glad you sorted it!
fcheslop
Re: Top Slide Fixed
« Reply #3 on: July 31, 2013, 05:29:19 PM »
1/4 BSF on my machine as well.
cheers
