Author Topic: Agnes.... 1/16 Scale Pollit & Wigzell Tandem Compound Condensing Engine.  (Read 67360 times)
Re: Agnes.... 1/16 Scale Pollit & Wigzell Tandem Compound Condensing Engine.
« Reply #150 on: November 27, 2016, 08:13:06 AM »
Hi Phil, congratulations. That flywheel is magnificent.
« Reply #151 on: November 27, 2016, 02:15:12 PM »
I just spent the morning reading this thread from the beginning.  Truly inspirational.   :ThumbsUp:
Offline larry.doucet.37
« Reply #152 on: November 29, 2016, 04:15:12 PM »
Where can I get castings I'm new on this site from Nova Scotia Canada
« Reply #153 on: November 29, 2016, 04:34:37 PM »
 :lolb: You will have to read this thread from the beginning.
Online pgp001
  • West Yorkshire - UK
« Reply #154 on: April 17, 2017, 07:36:05 PM »
Just a quick update, I managed to make the last few parts for the barring engine over Easter and curiosity got the better of me and I had to hook it up to the garage compressor to see what happened.
This was just a quick lash up with no regulator or control valve, but I was very pleased that it ran first time with no valve adjustments needed, I will fine tune it on final assembly but at least I can say something is nearly finished for a change.
Excuse the hurried video, I was running out of time.
<a href="https://www.youtube.com/watch?v=b45DiupolxM" target="_blank">http://www.youtube.com/watch?v=b45DiupolxM</a>
Phil
« Reply #155 on: April 17, 2017, 08:09:52 PM »
Nice!
« Reply #156 on: April 17, 2017, 10:07:28 PM »
Nice one Phil.
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #157 on: April 17, 2017, 11:58:34 PM »
Great job Phil, looks and sounds the part  :)
Offline Alan Haisley
« Reply #158 on: April 18, 2017, 03:12:38 PM »
Very nice.
Offline Rivergypsy
« Reply #159 on: April 20, 2017, 12:32:00 PM »
Loving this build - well done! :ThumbsUp:
Online pgp001
« Reply #160 on: August 12, 2017, 06:12:07 PM »
I bet you all thought I had made some progress on Agnes and was posting up loads of new photo's.
Sorry to disappoint you, but all I am doing is testing out the Coppermine photo hosting site to see how it works before I too eventually get kicked out of Photobucket.
Actually I will very shortly have some new photo's to share, as I have almost finished the process of fitting hundreds (well it seemed like it) of Walnut floorboards to the engine base board.
Phil
Online pgp001
« Reply #161 on: December 06, 2017, 08:43:41 PM »
Floor boards as promised. They are 3mm thick x 16mm wide solid Walnut all individually cut to size and stuck on with Gorilla glue and finished off with a few coats of Danish oil.
The two trophies were for the little Barring Engine at the Bradford MES annual exhibition last year.
Phil
« Reply #162 on: December 06, 2017, 09:28:17 PM »
Good heavens, if those cups are for the barring engine, the ones you get for the finished engine could be used as municipal water towers!
Spectacular work,
« Reply #163 on: December 06, 2017, 10:23:04 PM »
Spectacular work,
 :lolb:
Seriously though - it's a big engine and good looking so far  :ThumbsUp:
Offline Gas_mantle
  • North Yorks - UK.
« Reply #164 on: December 06, 2017, 11:08:11 PM »
Looking great Phil, when are we going to steam it up  ;)
