Author Topic: Blower for The Demon V8  (Read 49350 times)
Offline metalmad
Re: Blower for The Demon V8
« Reply #30 on: June 27, 2013, 02:32:36 AM »
Holy Cow Batman, That's Blown  :praise2: :praise2:
Offline pgp001
  • West Yorkshire - UK
« Reply #31 on: June 27, 2013, 07:41:22 AM »
Just a quick tip for you.
Make sure you have no backlash in the blower gears that mate the two rotating parts together, the clearances between the the two will be very small and any backlash will hammer them to pieces.
I cut some gear teeth on the blanks for a fellow model engineer who is building a blower Bentley engine, the accuracy had to be spot on.
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #32 on: June 27, 2013, 10:54:33 PM »
Yeah buddy! Got it covered. I have set some very high standards for the blower parts. When I indicated in the blanks I wanted less than .001 difference. I got both to better than that. The gears should have no trouble keeping the rotors apart. I'm setup for round 2. The second blank is shimmed and indicated in. I would cut it right now but we are getting pounded with rain and with my luck the power would go out 10 minutes before it's done.
Offline NickG
« Reply #33 on: June 28, 2013, 04:12:10 PM »
Crazy but excellent!
« Reply #34 on: June 28, 2013, 11:29:30 PM »
Well! It's official, I now have a pair.
They still need to be deburred and geared together so i can see how they run together. The fit seems very promising. I'm sure there will need to me some fine fitting with some fine grit sand paper.
Offline pgp001
« Reply #35 on: June 28, 2013, 11:54:15 PM »
Very nice  :ThumbsUp:
Phil
« Reply #36 on: June 29, 2013, 12:24:15 AM »
Damn Bubba!.....I hope your not going to over drive that beast!....seems like a whole lot a blower!
Beautiful!
« Reply #37 on: June 29, 2013, 12:53:53 AM »
25% overdrive.
Offline metalmad
« Reply #38 on: June 29, 2013, 02:43:02 AM »
I love It  :praise2: :praise2: :praise2: :praise2: :praise2:
« Reply #39 on: June 29, 2013, 02:49:38 AM »
25% overdrive.
Just as long as pistons don't start swapping rods....just sayin!!
« Reply #40 on: June 29, 2013, 05:34:41 PM »
We've seen some wanting to run and we've seen "runnahs", but we ain't ever seen none busting a blower and sticking some rods through the crankcase. Give her Hell, Bubba.  25 overdrive, on gas, with a good stiff alky back. On  a long lonesome hiway east of Omaha 8) :cheers:
E
« Reply #41 on: June 30, 2013, 06:29:36 PM »
After 2 days of filing, dying, testing , and sanding, fitting, massageing, and tinkering, well you get the point. The rotors are fitted to the case. The rotors free spin and nothing touches nothing.
« Last Edit: June 30, 2013, 08:12:30 PM by stevehuckss396 »
« Reply #42 on: June 30, 2013, 08:15:32 PM »
Yeah! we can listen to the engine moaning out it's one note song.
« Reply #43 on: July 06, 2013, 12:29:21 AM »
I have the new gear cover done. Just need to sand blast it and thread the holes.
« Reply #44 on: July 06, 2013, 02:29:40 AM »
Hi Steve,
 Being following your build, amazing, is about all I can say. Not sure if its just me but all your photos have "Photobucket" "Look who's" popular" instead of those great photos, the moves seem OK. Have check on both a iPad & windoz machines, same issue.
