Author Topic: Blower for The Demon V8  (Read 49438 times)
Offline stevehuckss396
  • Sterling Heights, MI USA
« on: June 21, 2013, 01:05:43 AM »
I got the bug to make a few parts for the Demon blower. I have a lot of prototype parts but have never built one so I decided to make the intake manifold and go up from there. I used the manual mill to rough out the basic shape of the intake and then the CNC mill to start shaping things. It took 3 tools and about an hour and a half to get to this point.
I also made a pattern and poured a few cases for the blower.
I will most likely bounce back and fourth between this and the mini bikes so both builds will take twice as long now.
Offline metalmad
Re: Blower for The Demon V8
« Reply #1 on: June 21, 2013, 01:10:31 AM »
That is just plane Sexy Steve
Maybe I will pick up a few pointers  :praise2:
« Reply #2 on: June 21, 2013, 04:07:18 AM »
Awesome Steve!  :praise2: :praise2:
« Reply #3 on: June 21, 2013, 04:26:32 AM »
I like it Bubba!
« Reply #4 on: June 21, 2013, 11:48:43 AM »
Amazing stuff Steve...you may have to change the name to Screamin' Demon though with this blower installed :)
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #5 on: June 21, 2013, 01:09:38 PM »
Keep in mind that Steve's "twice as long" is everyone else's half as long. I'm watching this amazing work.
Mosey :cartwheel: :cartwheel:
« Reply #6 on: June 21, 2013, 09:39:15 PM »
Good one!!
Offline Mosey
« Reply #7 on: June 21, 2013, 10:20:01 PM »
Don't forget, I'm always on ya.
Mosey
« Reply #8 on: June 22, 2013, 07:41:15 PM »
Got the top and bottom complete. I just need to drill the holes to mount it and port the blower to the cylinders.
« Reply #9 on: June 23, 2013, 02:26:55 AM »
Man that looks awesome Steve. That will be a nice engine  Love the detail on the blower I like..........  :praise2: :praise2:
« Reply #10 on: June 23, 2013, 10:40:57 AM »
OK Bubba....Awesome work as usual.....but help me out here
B D S .......?
« Reply #11 on: June 23, 2013, 11:51:47 AM »
B D S .......?
Blower Drive Service
http://www.blowerdriveservice.com/
« Reply #12 on: June 23, 2013, 11:53:33 AM »
Cool!
I was wondering if it began with Bubba...... 8)
« Reply #13 on: June 23, 2013, 04:28:42 PM »
Bubba's Drive Service!  I like it!
The intake is complete. The ports are drilled and the coolant passages are in. For the first time a blower is bolted to one of my demon blocks.
I'm liking it so far.
« Reply #14 on: June 25, 2013, 09:56:09 PM »
I have my blanks made up for the rotors. The length is dead on and the diameter is .125 inch larger than needed. The shaft is a pressed fit but I used a grooving tool and made some .010 deep grooves and filled them with loc-tite before i rammed the shaft thru.
Here's my setup. The fixture is steel with brass bushings. I spent better than an hour shimming and tapping and indicating to make sure i am perfectly aligned. It's ready to go. If work gets rained out tomorrow I might take a run at one rotor. The RT is for rotating and holding position. The fixture does all the work. With a .188 shaft I didn't want to rely on the RT to support the work. I was worried about the center shaft flexing. I have only allowed .005 clearance in the case so I need all the advantage I can get.
