That'll work!Dave
Tom,Make a few passes staying violently away from the edge of the master. As a matter of fact take two passes staying about 1/4" away from the edges of the master. I ran into this scraping my angle master in that it's really difficult to mark it without influencing it. I believe your crowned in the middle ....if the middle hollows out, you'll know where you are. As it sits, you need more coverage up to the edge to reach the inside of the dovetail accurately. I resorted to making a flat master to mark up the angled master. This was from a Master Scraper at Moore, whom I brought the master too to check my work. He said these small masters can be tough and that was the way he recommended to fix it.I would try to hollow it out a bit so you know you sitting on the periphery. Then let the bearing progress towards the center.
And we're talking two crossed passes here....don't go back to roughing it...just relieve it a bit to make sure it's not crowned.
It's hard to say for sure Tom, but a small change in procedure like I described, if it is flat will POP right away, and you'll only be a cycle or two away from being flat and Knowing it.[...]Additionally, don't handle that master to much. Your hands will make it move around from thermal effects, and you'll go back in the morning and find a different result and wonder why.....ask me how I know this....
