Well the first cutter performed beautifully on the little rotary table, and would appear to be able to go several more rounds without resharpening. I ran it at about 600rpm, which according to the Tubal Cain book is below recommended speed. On none of the four slots did it feel much above body temperature.
The speed was dropped to 300rpm for the second cutter, which is 5/8" diameter. It only had 1 slot to cut, and it appeared to do it as well as the first. This was in the foot casting of the GHT quick action hand rest. I did a lot of his designs when I was doing a foundry course some years ago. Don't be fooled by the appearance of the slot in the end of the casting. Even a cursory look at the cutter will show that it's turned itself into a dovetail cutter of an unknown angle. No prizes for guessing the angle.
I'm wondering firstly, if there was a hard section in the casting that the cutter could not deal with, the dovetailing begins about an inch down the slot. I'm tending to discount this theory, as I don't see why a hard spot would be in the centre of the casting surrounded by lovely soft cast iron. The endmill that made the slot had no trouble at all.
Which leaves the cutter, and I'm wondering if, despite the good soaking it got in the oven, it was not of a consistent hardness. Well, I'll make another cutter and try again. If the casting proves truculent, I have another to play with.
Cheers, Hugh.
