Author Topic: Anybody guess what this is going to be???  (Read 17915 times)
Offline cfellows
« on: June 12, 2013, 09:50:18 PM »
Here's a hint...
It's going to be an air core dynamo, obviously.  I started with a 4" square piece of 1" thick, HDPE (High Density Polyethylene).  Also sometimes called Seaboard.
It's used a lot in the boating industry.  It's pretty rigid, but does have some give to it.  Machines like a dream.  I decided to make the core out of plastic since it won't put out a lot of power and, more importantly, the Fairbanks compressed air engine should have enough power to run it and light up a few LED's.  Here I'm drilling a 1/4" hole in the center.
Next I cut circular grooves on both sides.  These grooves will form the coil winding channel.
I changed rotary tables and started whittling away everything that didn't look like a dynamo core.
This will be a single phase AC alternator.  I used a lot of the information provided by Manfred Albert over here:
http://www.homemodelenginemachinist.com/f23/dynamo-build-castings-17756/
I'll be using #24 magnet wire, hoping to get 60 or 70 turns per coil.  They will all be hooked in series.  Not all sure what kind of voltage and current I'll get out of this thing, but since LED's will run on about 3 volts or less, I think it will be sufficient.
Chuck
Re: Anybody guess what this is going to be???
« Reply #1 on: June 12, 2013, 09:55:01 PM »
This is going to be interesting.
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #2 on: June 12, 2013, 09:59:28 PM »
Interesting indeed - and a very nice start!
Offline dale
« Reply #3 on: June 12, 2013, 10:12:13 PM »
Oh I get it! The engine turns the dyno,the dyno powers up the air compressor, the compressor supplies nourishing air to the engine! very ingenious :Lol: Seriously another great project, always interesting and informative
Online b.lindsey
« Reply #4 on: June 12, 2013, 10:43:25 PM »
Will definitely be following along Chuck....nice start on it!!
Offline stevehuckss396
  • Sterling Heights, MI
« Reply #5 on: June 12, 2013, 11:04:27 PM »
I don't know Chuck! Something like this?
Offline Bezalel
  • - Skype:Bezalel2000
« Reply #6 on: June 12, 2013, 11:31:48 PM »
Chuck
nicely done  :ThumbsUp:
I'll be very interested to see what sort of efficiency the air core has,
Of course you're gunna knock up an iron one, just  for the comparison aren't you?    :stir:
Bez
Queensland - wet one day, humid the next
« Reply #7 on: June 13, 2013, 12:01:16 AM »
"Anybody guess what this is going to be???"
Mine?  ;D
« Reply #8 on: June 13, 2013, 12:03:55 AM »
Very interesting Chuck, I will be tagging along. Electrical devices always interest me.
Online b.lindsey
« Reply #9 on: June 13, 2013, 12:11:00 AM »
Nice try zee....this from someone who has to wait till T goes out of town to to have chicken cheesesteak  :lolb: :lolb:
« Reply #10 on: June 13, 2013, 07:27:01 AM »
Chuck, I would like to be following this along but I should have said earlier that my internet provider  :hammerbash:  :hammerbash: won't let me see your photos because it has decided to block acess to where ever you are hosting them.  :-\
Offline Bezalel
« Reply #11 on: June 13, 2013, 07:44:39 AM »
Hi Chuck
If you don't mind me asking how did you arrive at the 60-70 turns?
 :thinking:
If I do the maths it equates to coil height of 5mm to 5.5mm - it looks a bit bigger than that, maybe
1/4" which should give you about 95 turns (tight wound)
N=0.707*H2/d2
N= Number of turns
d=diameter of wire #24 = 0.55mm
H=Height of Coil(along the coil axis)
Where H=5,     N=60
Where H=5.5   N=70
Where H=6.35 N=95
of course there is a tidy factor. If I was winding them myself in a hurry you would have to half all those calculations   :Lol:
Bez
Offline Bezalel
« Reply #12 on: June 13, 2013, 01:44:13 PM »
Ok I figured out why the difference.
   The  N=√2/2*H2/dassmes the coil is wound onto a regular flat former.  :embarassed:
But these formers are concave (same shape as the side of the endmill) so there is no room for windings in the corners at the top and bottom of the coil.   :facepalm:
I'm looking forward to seeing the real thing in action Chuck,  thanks for inviting us along.
Bez
Offline MuellerNick
  • Germany // Outback of Munich
    • Motor-Manufaktur
« Reply #13 on: June 13, 2013, 02:12:13 PM »
Chuck,
do you intend the coils of the stator to be fake and have magnets inside? If not, a coil without (iron; better ferromagnetic) core is quite ineffective. For iron, µr is 300…10000, for ferrites, it is 4…15000. So that's the factor your field strength is reduced by not having a core.
Nick
Offline Ian S C
« Reply #14 on: June 13, 2013, 02:54:32 PM »
I built a little alternator a few weeks ago, it was a little shaded pole motor, 850 rpm type. I took out the armature, and made a new one, it is a 6 finger claw (similar automotive alternator), with 3 ferrite magnets removed from old speakers inside, this will produce about 90V, and gives useful power when fed through a transformer, and a bridge rectifier, to give about 12V.  This alternator was designed for the Stuart S9 .
