Author Topic: Clamps for use on small lathe faceplates  (Read 24708 times)
Offline Alan Haisley
Re: Clamps for use on small lathe faceplates
« Reply #15 on: June 12, 2013, 07:44:45 PM »
On the Sherline Tips site: http://www.sherline.com/tip3.htm is an example of a small surface clamp that could be scaled further. You would obviously need to fabricate appropriately sized T-nuts, but a pair, or even more, of these might suit. These are designed to expose the entire top  of the part, which could be handy.
Alan
« Reply #16 on: June 12, 2013, 07:49:28 PM »
They are cute  :ThumbsUp:
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #17 on: June 12, 2013, 09:56:59 PM »
I have to agree that holes are better than slots in small faceplates - that's how I did the 3" one I made for the Myford.
« Reply #18 on: June 12, 2013, 11:25:31 PM »
Well   Even the big ones.....10"   25 pounds
Pictures later.
« Reply #19 on: June 13, 2013, 03:08:15 AM »
Little clamps....they are on a plate, siting on top of a 123 block
And big....one I made for my Logan...10" diameter.
I also have a 3C faceplate..about 4 1/2 inch diameter .....which I think is just beautiful...but with no holes or slots yet.   I'll be putting a true running 1/4" hole in the middle and 10-32 tapped holes in a similar pattern as the big faceplate
Offline Tin Falcon
  • Down Jersey USA
« Reply #20 on: June 13, 2013, 12:01:33 PM »
Thanks Alan saved a copy to my shop notes file.
Tin
« Reply #21 on: June 14, 2013, 02:11:58 PM »
Due to the lack of space for the clamps, which meant they had to be very short, I chose to make them out of the corner of a piece of angle. a 3.2mm shoulder was left on the underside to provide the stand off and I have made two curved and two pointed clamps. They are mounted by a tee nut which is just a piece of 9.53mm stainless with a pair of flats to fit the faceplate and an M5 thread in the face:
They fit nicely around the 2.4mm end of the Crosskill cylinder:
You can see how little space I would have had for a second adjusting screw  :-\ so I gave up on that idea.
I do fancy some faceplate dogs as well  :naughty:
Offline PeterE
« Reply #22 on: June 14, 2013, 02:59:48 PM »
Oooohh really neat little clamps Jo  :ThumbsUp:
What size angle bar? Looks like somewhere around 35x35x4 and piece about 20 mm long?
Definately on my ToDo-list!
BR
/Peter
« Reply #23 on: June 14, 2013, 03:27:00 PM »
Peter, nearly spot on  :ThumbsUp: It is actually a bit of imperial 3/16" thick * 1 1/4" angle (4.76 * 31. 75mm angle)
I ended up leaving them at 25mm long.
« Reply #24 on: June 14, 2013, 04:06:50 PM »
I would be tempted to prep a handful of blanks to keep on hand if different ends needed to be custom made.  :thinking:
Alan
« Reply #25 on: June 14, 2013, 05:02:20 PM »
Strangely enough Alan I had been considering just that with the short end that is left of that piece of angle  :ThumbsUp:.
To keep from getting bored I have knocked up a set of faceplate dogs:
I have intentionally kept to the same M5 allen screws on these as for the previous clamps because it is the same size as the Cowells toolpost  ;)
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #26 on: June 14, 2013, 05:21:58 PM »
Thanks Jo,
I just added to my to do list.
Dan
ShaylocoDan
Offline gmac
  • British Columbia Canada
« Reply #27 on: June 14, 2013, 05:25:58 PM »
Gee, glad I woke up this morning! Thanks Jo, I think the Taig and 9x20 are in for some new tooling!
How wide were the clamps (version 1) looks like about 3/8"?
For the faceplate dogs could we see/explain how they are mounted to the backside of the faceplate?
I'm sitting at the computer making a CoC of the parts  ::)
Cheers  Garry
« Reply #28 on: June 14, 2013, 05:28:34 PM »
You might want 3 or so of those with the screw angled in towards the face of the faceplate to make sure the part is "bedded" .....just like a shaper toe clamp
« Reply #29 on: June 14, 2013, 05:39:38 PM »
Dave: I was thinking about making some brass ends to go on those screws and I was thinking that one set could be angled to provide just that type of clamping effect  :ThumbsUp: Another could be v'ed and then flat...
Garry, the clamps were made 12mm wide. The mounting for the dogs is simple they were turned round to fit through the hole and then have an M6 screw thread on the end on which is a washer and nut.
