Author Topic: Die filer  (Read 20857 times)
Offline tel
  • Bathurst District, NSW, Oz.
Re: Die filer
« Reply #45 on: July 05, 2013, 06:18:57 AM »
... just a rough lash up with an old drill, and old vee belt and some odds n ends - but it works!
A bit of a (free-form) play in the third pic, and some blurry swarf just for Jo!
Offline ths
Die filer
« Reply #46 on: July 05, 2013, 08:57:51 AM »
She's an active little tyke Tel, looks great. How are you lubricating the large bronze bush, and what sort of stroke does it have? I know how I can find this out, and so do you, but the others may wish to find out.
Hugh.
Offline tel
Re: Die filer
« Reply #47 on: July 05, 2013, 09:29:02 AM »
 ;D There's a grease nipple in the end of the crankshaft, behind the vee pulley, that sents grease to the eccentric bush and the plain main bearing. The top pin and the vertical rod are lubed by manual oiling.
Stroke is 1 1/4" - a little shorter than the original plans, but I had to modify it a bit to make the materials I had work.
Speed, as far as I can judge, at the moment is around 140 strokes per min - probably a bit far but I am waiting on a speed controller for a little 300w motor I have on hand here, when that arrives I can make up a proper drive arrangement and get it all mounted 'somewhere'. Might run the tacho on it tomorrow anyway, just as a matter of interest.
Thus far I am happy! Next, a hold down for it (not that a lifting workpiece is really a problem) but I am thinking one that will mount on either rear corner of the table, swivel and adjust in and out.
Re: Die filer
« Reply #48 on: July 05, 2013, 11:12:24 AM »
Thanks for the video Tel...looks like you're nearly in business once that motor controller comes in. Nice project and very well done!!!
Re: Die filer
« Reply #49 on: July 05, 2013, 02:50:01 PM »
That's awesome Tel!.......Nice job
got me somewhat lathered about the whole prospect now!...
Offline cfellows
Re: Die filer
« Reply #50 on: July 05, 2013, 04:57:24 PM »
Just curious, Tel, is there a particular reason you opted for an eccentric/crank drive rather than a scotch yoke type drive?
Chuck
Re: Die filer
« Reply #51 on: July 05, 2013, 06:53:39 PM »
Hey bloke, what was the winning hand :LittleDevil:. Really, great job. When you get it all anchored and geared up I'd like to see some video from under the table. I see the way it runs, I'm just gotta a little confusion on how. As a matter, kinda reminds me of myself in me younger days :lolb: :LittleDevil: :lolb:
Yo redneck,
Eric
Offline tel
Re: Die filer
« Reply #52 on: July 05, 2013, 08:49:17 PM »
Thanks guys!
Yeah Eric - 'Round and round went the great big wheel ....'
Chuck
Chuck, that's the way the AME version was drawn - I suspect because of the much great bearing surface on the eccentric.
Offline tel
Re: Die filer
« Reply #53 on: July 15, 2013, 07:15:58 AM »
Some progress on the horizon - this arrived today
Offline ths
Die filer
« Reply #54 on: July 15, 2013, 08:14:47 AM »
What sort of motor is it? DC?
Offline tel
Re: Die filer
« Reply #55 on: July 15, 2013, 08:45:17 AM »
I wish! Life would be much simpler. It's a 1/2 hp 240v 2800rpm motor, hence the need for the speed controller.
Offline ths
Die filer
« Reply #56 on: July 15, 2013, 09:16:52 AM »
I didn't know you could control the speed of those motors electrically. Well, not cheaply or efficiently. Looking forward to hearing of the results, hoping you'll excuse the tautology.
Offline tel
Re: Die filer
« Reply #57 on: July 15, 2013, 09:25:11 AM »
It's one of these
http://www.ebay.com.au/itm/231009675000?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
The ratings look OK, so I have hopes, but I'm afraid I am a bit of a babe in the woods when it comes to electronics. Time will tell - hopefully try it tomorrow.
Offline ths
Die filer
« Reply #58 on: July 15, 2013, 10:25:43 AM »
I see you spared no expense!
Offline tel
Re: Die filer
« Reply #59 on: July 15, 2013, 10:36:16 AM »
 ;D Nope! Last of the high rollers, that's me!
Database Error
Back
