Author Topic: Die filer  (Read 17586 times)
Offline tel
  • Bathurst District, NSW, Oz.
Re: Die filer
« Reply #15 on: June 24, 2013, 10:38:54 PM »
The table will be tiltable tho I think I'm going to have to modify it a bit - as drawn it is only supported on one side, which doesn't seem such a good idea to me.
Re: Die filer
« Reply #16 on: June 25, 2013, 04:24:37 PM »
Tel on the connecting rod, did you pin the brass bushing in place? I seem to see two pins. Just curious.....
Nice work by the way.
Offline tel
Re: Die filer
« Reply #17 on: June 25, 2013, 09:44:41 PM »
Well spotted Don! Yes, I did put two pins in - more as a 'belt 'n braces' precaution than anything. That 2 3/16" od bush seemed a bit big to rely on the glue alone.
Offline ths
Die filer
« Reply #18 on: June 25, 2013, 10:19:17 PM »
And did said bush come from a rather large bit of solid bronze? I've looked, but can't find anything remotely suitable from bearing suppliers.
Hugh.
Offline tel
Re: Die filer
« Reply #19 on: June 25, 2013, 10:27:57 PM »
.... a large stub of cored bronze, yes. Probably enough left here for another if you are in need.
Our local scrappy used to get a good few stub ends of bronze in and I have accumulated a few - not as many as I should have tho!  ;) Been a bit of a drought lately  :(
Offline tel
Re: Die filer
« Reply #20 on: June 25, 2013, 10:36:53 PM »
Offline ths
Die filer
« Reply #21 on: June 26, 2013, 12:17:33 AM »
I think we must have been seeing what George had at the same time. I'll let you know if I need it, many thanks. Currently holed up at Milsons Point above Luna Park at a mates place. Flooded out at home since Monday, may get there tomorrow.
Hugh.
Re: Die filer
« Reply #22 on: June 26, 2013, 12:36:23 AM »
Best of luck with the flood Hugh!....hope it wasn't too bad! Glad your safe!
Offline tel
Re: Die filer
« Reply #23 on: June 26, 2013, 02:45:03 AM »
Yeah, keep safe - floods are not good things to argue with!
Just had a look - there's about 2 1/2" of that bronze there - if you need it it would be best to send the whole piece - much easier to make the bush with something to hold it by.
Offline ths
Die filer
« Reply #24 on: June 26, 2013, 06:52:42 AM »
I'm very safe here! Anything over 50mm and we're often flooded in (much better than out), but it looks like it'll be more than 300mm over 3 1/2 days.
I'll let you know about the bronze Tel, I have so much to do, learning how to walk and getting back to earning a living at the top of the list. And building a shed, more to come. The die filer is up there, though.
Cheers, Hugh.
Offline tel
Re: Die filer
« Reply #25 on: June 27, 2013, 04:16:06 AM »
A little further along - an oospy on the bottom arm, but I'll have to live with that - might look a bit better after final cleanup.
Offline ths
Die filer
« Reply #26 on: June 27, 2013, 04:37:56 AM »
Tiny oopsy. Paint the arms matt black, no-one will notice. Looking the business, though.
Hugh.
Offline tel
Re: Die filer
« Reply #27 on: June 27, 2013, 10:25:26 AM »
Well, it will be obscured under the work table, so hopefully yes! Still annoying when you do things like that tho' :(
Re: Die filer
« Reply #28 on: June 27, 2013, 10:28:16 AM »
Hugh.
It does look the business.....I have another tool to build!....... ::)....after the Wallaby...
Offline Maryak
Re: Die filer
« Reply #29 on: June 27, 2013, 12:26:23 PM »
Just make the same Oopsy on tother side and everybody will think its part of the design.  ;)
Best Regards
