I didn't get much done this weekend, plenty to do around the house. However I did get the last arm bored. After boring the .875" hole I pulled out the clamping pad and got a surprise. Some how I must of used the .750" value for the offset dimenisions for the clamping pad. When I bored the .875" hole the bore was just cutting into the thread of the securing screw.
I have one way out of this, the screw is .250" and I can go down to the next diameter and that would be a number 12 screw. This would allow the screw to pass and not make contact with the column and I will have to make a new clamping pad. I also have to make another clamping pad for the alloy base. When I picked it up to look at it the pad fell out. I quess you know that that dam little gremlin snatched it up and no where to be found.
Now I have a rather large floor area in my shop and it is gone.
Anyway I have a few photos no much but just to show how the pillar tool is used to do staking on the Micro Attachment know that I remade and that another story.
This first phot show how the Pillar tool is being used for staking my Micro dial.
The last arm complete and has to have the clamping pad redone to accommodate the number 12 screw. I want to show how they line up together with column and .750" shaft through both arms.
Thats all I have for now and work starts tomorrrow so it will be a while before I get more done.
Thanks for looking in.
