Author Topic: Boringhead  (Read 6436 times)
Offline crankshafter
  • Molde, Norway
Boringhead
« on: May 22, 2013, 06:00:06 PM »
Hi all.
I made my self a new boringhead for the Aciera F3.
The F3 have not so much "daylight" betwin the table and vert. head so I made the boringhead with 15mm(largest collet I have) stright tang. but first I had to make small 45* dovetailcutter. I was a little bit worried if it would hold up but it did just fine, even the boringhead was made out of som mystery SS steel. I scaled down the plans from Mr Ishimura( Nifty Amigo)
Here are some pics. First from making the cutter.
And here are the "Female" finished :LittleDevil:
And here's the two together :naughty:
And here is it finished.
I tryed it last evening with a homemade cutter and it working just works great  :whoohoo:
Regards
CS
"I cut it twice, and it's still to short"!!??">#%
Re: Boringhead
« Reply #1 on: May 22, 2013, 06:20:02 PM »
Nice one Mosey.  I am sure you will be using it regularly.
  • Molde, Norway
Re: Boringhead
« Reply #2 on: May 22, 2013, 07:26:33 PM »
Vince.
I'm not Mosey but I have a F3 aswell  :cheers:
Btw I forgot to show you how small it is  :LickLips:
Here we go.
CS
Re: Boringhead
« Reply #3 on: May 22, 2013, 08:16:00 PM »
Sorry about that CS.  I saw Aciera and thought it was Mosey.
Offline arnoldb
  • Windhoek, Namibia
Re: Boringhead
« Reply #4 on: May 22, 2013, 08:34:55 PM »
Very well done CS  :ThumbsUp:
Two questions if you don't mind...
Does it have a gib strip between the locking screws and the dovetail ? - I can't see one, and if the screws are acting directly on the dovetail, they are going to damage it - unless you overcame that problem in some other way...
What thread pitch did you use for the leadscrew ? - I'm assuming it's metric as you're from Europe.
Kind regards, Arnold
  • Molde, Norway
Re: Boringhead
« Reply #5 on: May 22, 2013, 10:22:35 PM »
Hi again.
Vince: your welcome ;)
Arold: I use inserts in front of the bolts filed to 45 * the two outer acting as "gibs* and the centerfor locking.
I made the adjustingbolt with M10x1threads. But if I have to do it over I would have used M 10x0.5 pitch.
Here is a better pics. that's show how small it is.
Best...
CS
« Last Edit: May 22, 2013, 10:28:39 PM by crankshafter »
Offline Maryak
Re: Boringhead
« Reply #6 on: May 22, 2013, 10:43:56 PM »
CS,
A very nice addition to your tool box  :praise2:
Best Regards
Offline tel
  • Bathurst District, NSW, Oz.
Re: Boringhead
« Reply #7 on: May 22, 2013, 11:04:48 PM »
Lovely little gizmo - I'm tempted to have a go at one. :NotWorthy:
Offline Bearcar1
  • Chicagoland Area, USA
Re: Boringhead
« Reply #8 on: May 22, 2013, 11:23:56 PM »
Very slick CS, I like it. A perfect size for those smaller holes. Arnold already made the inquiries that I had so I'll just say "great job"  :ThumbsUp:
BC1
« Last Edit: May 23, 2013, 06:00:27 AM by Bearcar1 »
Re: Boringhead
« Reply #9 on: May 23, 2013, 12:21:05 AM »
That last picture really shows how small it is CS. Very nicely done and i suspect it will see a lot of use also.
Re: Boringhead
« Reply #10 on: May 23, 2013, 12:47:43 AM »
Man that is small a perfect boring head for those small hole. I love it.  :ThumbsUp:
Offline cfellows
Re: Boringhead
« Reply #11 on: May 23, 2013, 03:13:47 PM »
Very nice work, CS.
Chuck
Offline Camm-1
  • Sweden
Re: Boringhead
« Reply #12 on: May 23, 2013, 06:44:04 PM »
Looks super Bård :ThumbsUp:
Made one myself, the first projekt but 50 mm wide and works OK BUT,, I didn`t have any fine treaded skrews or taps  so
it´s not easy to adjust :shrug:
Ove
Offline MuellerNick
  • Germany // Outback of Munich
    • Motor-Manufaktur
Re: Boringhead
« Reply #13 on: May 23, 2013, 09:13:21 PM »
Almost too cute to be used.  :Love:
Nick
Re: Boringhead
« Reply #14 on: May 24, 2013, 02:21:24 AM »
Nick
Isn't it?! 8) :Love:
