Author Topic: What to do with a tiny XY table?  (Read 4612 times)
Offline John Hill
  • Playing in my shed at Ashburton, New Zealand.
« on: April 28, 2013, 07:36:28 AM »
It is not really an XY table, it is a Sherline mini lathe without headstock or motor..
Sherline bed by MrJohnHill, on Flickr
.... I got it because I need the tail stock for another Sherline I have with a damaged tailstock.
So what to do with the bed and cross slide?
P.S. These are the original, genuine, made in Australia brass Sherline lathes.
Offline Maryak
Re: What to do with a tiny XY table?
« Reply #1 on: April 28, 2013, 08:30:17 AM »
Give it a head job  :shrug:
Offline John Hill
« Reply #2 on: April 28, 2013, 08:40:13 AM »
Well yes, a head job is probably the easiest part of a simple lathe to make,  but then I would have to make another tail stock and I only bought this bit to get a tailstock for my other Sherline...... Oh dear, it is all too much!..... :ROFL:
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #3 on: April 28, 2013, 08:46:55 AM »
Tuck it away somewhere safe - one day you will have a flash of inspiration.
Coupled with a bench grinder it could even form the basis of a neat tool grinder.
Offline ths
« Reply #4 on: April 28, 2013, 08:59:02 AM »
I think Tel's had the flash of inspiration. Power the lead screw with one of those 12v geared motors, cover the ways....
Hugh.
Offline John Hill
« Reply #5 on: April 28, 2013, 10:12:55 AM »
Intriguing, but I wish I knew how a tool grinder would work so that I could think of what else would be required. :shrug:
« Reply #6 on: April 28, 2013, 12:15:31 PM »
John,
I got one of those a long time ago...and put it to use as a pair of dividing centers....I used the headstock on a home built milling machine.
I will be re using the headstock as a toolpost spindle, and I still have the dividing centers.    I'll dig up a picture....but yes the original brass bed Australian verision it is....just like mine!
fcheslop
« Reply #7 on: April 28, 2013, 05:55:13 PM »
Maybe a little tool and cutter grinder hiding in there.
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #8 on: April 28, 2013, 08:31:47 PM »
You got me thinking...too bad the postage is a little high from NZ to NJ, or I'd say it would be nice as a stage on my sensitive drill press. Then, how about putting my sensitive drill over the slide on my jewelers lathe? Hmmm.
Mosey
