Author Topic: Distractions!  (Read 12496 times)
Offline ths
Distractions!
« Reply #30 on: April 30, 2013, 11:04:02 AM »
Fortunately, I'm not a real woman.
Re: Distractions!
« Reply #31 on: April 30, 2013, 11:10:45 AM »
 :lolb:
They say everyone has a twin somewhere in this world.
Re: Distractions!
« Reply #32 on: April 30, 2013, 11:12:02 AM »
 :lolb:
:lolb:
Offline tel
  • Bathurst District, NSW, Oz.
Re: Distractions!
« Reply #33 on: April 30, 2013, 11:14:26 AM »
Yeah, and I've done my 50 years on the splitting axe! The splitter is the best thing I ever did - with a usage of around 22ton per annum here it saves a lot of time and backaches. Mine is heavily modified - decent drawbar with towing hitch and jockey wheel, trailer axle and a decent set of wheels under it, splitting head beefed right up ..... At some point I will put a drop in light bar on it and get it road legal.
Re: Distractions!
« Reply #34 on: April 30, 2013, 11:17:23 AM »
Sounds better than the one I used Tel....It was heavily modified, but by a Master Mechanic...(my dad)....No safeties....a undersized engine...( it was free)
Cheap Yankee he was....still better than a maul or a sledge and wedges though!
Re: Distractions!
« Reply #35 on: April 30, 2013, 11:18:34 AM »
Tel,
Do you have a drawing for such a beasty  :naughty:? The ones available in the UK are little wimps, hence  I find it faster to do it by hand.
Offline ths
Distractions!
« Reply #36 on: April 30, 2013, 11:22:53 AM »
Strangely enough, I thought Zee would pipe up.
We're mostly blue gum here Tel, pretty good, but you'd possibly get the boxes, stringy's and iron barks, a bit hotter I'd say. 22t, how many fireplaces?
Hugh
Re: Distractions!
« Reply #37 on: April 30, 2013, 11:28:18 AM »
Hugh
That's a good burn...5-7 cord of wood I suspect....depending if it's hardwood or not...might be less
Offline tel
Re: Distractions!
« Reply #38 on: April 30, 2013, 11:37:18 AM »
Yep, mostly yellow box, blakey's red gum and some red stringy to temper it down a bit. Kitchen stove goes all year round at 1t/month, which also gives us our hot water. An open fire, wood heater and occasionally the pot-belly in the workshop eat the other 10 t.
It's pretty heavy stuff Dave - Yellow Box is around 1100kg/cubic metre
Offline tel
Re: Distractions!
« Reply #39 on: April 30, 2013, 11:41:51 AM »
Tel,
Mine's from Kinchrome - they were a batch that were downgraded from 20t to 8t due to the cutting head - been re-graded back to 20t (and then some) - bought it cheap, spent as much again on it and ended up with a good machine. 6hp petrol engine & 20t double acting ram with two-way cutting.
Yow! I see they list at $2800 - I paid $900!
Below in the original form
« Last Edit: April 30, 2013, 11:45:36 AM by tel »
Re: Distractions!
« Reply #40 on: April 30, 2013, 11:46:02 AM »
The domestic ones in this country are in the main 4 tonners. :ShakeHead:
Re: Distractions!
« Reply #41 on: April 30, 2013, 11:48:30 AM »
Mostly White and Red Oak and lots of Maple....there used to be a healthy supply of Elm till dutch elm disease got them ALL...though that is miserable to split and can only be done after a years seasoning.....even then, you need an axe and the splitter.
Occasionally some hickory...but that's very rare.
I have a fireplace, ( piss poor design...I think I burn more fuel with the fireplace lit!)   but since the kids were born...haven't really used it......guess I got the wood splitting thing out of my system when I was a kid.
Offline tel
Re: Distractions!
« Reply #42 on: April 30, 2013, 11:49:10 AM »
Toys then - my brother has one, electric, cute little thing. might make a good workshop press.
Offline Steamer5
  • The "Naki" New Zealand
Re: Distractions!
« Reply #43 on: April 30, 2013, 11:58:36 AM »
Hay Tel,
 If you are getting thru that much you need one of these.....
<a href="https://www.youtube.com/watch?v=KdXzaGFkWfU" target="_blank">http://www.youtube.com/watch?v=KdXzaGFkWfU</a>
Hopefully th elink works if not Youtube ....log splitter, & look for the Bob cat,
Cheers Kerrin
Offline tel
Re: Distractions!
« Reply #44 on: April 30, 2013, 12:09:24 PM »
That's the way to do it - 20t in an arvo!
