Author Topic: An experiment  (Read 6337 times)
Offline Lofty76
An experiment
« on: April 18, 2013, 09:45:06 PM »
Some years ago someone bought me one of those little 6" bench grinders from B & Q.
For ages it sat in its box unused as the plastic base was next to useless, and the guards pressed tin, and as I already had 8" grinders in the shop I really couldn't see a use for it.
However, right in the middle of my current project I realised that my little toolpost grinder was not going to be big enough to grind some crankshaft journals.
Then, a small spark of an idea formed, would it work? unknown, but for the want of a little whittling it was worth a try.
First of all the plastic base was not required and the grinder was stripped to basic parts to reveal a reasonable motor and smooth bearings.
Now to make a new base that will fit in place of a Warco GH1330 topslide.
Take a chunk of 5" diameter hard ally bar and face, then reduce the diameter to match the topslide mounting.
Offline Lofty76
Re: An experiment
« Reply #1 on: April 18, 2013, 09:47:10 PM »
Then to cut off the excess - calculated by working out the required centre height, and leaving a little spare for facing off
Offline Lofty76
Re: An experiment
« Reply #2 on: April 18, 2013, 09:48:20 PM »
Face off to allow for the curvature of the motor.
Offline Lofty76
Re: An experiment
« Reply #3 on: April 18, 2013, 09:50:38 PM »
The next part was to reduce the sides to a rectangle, initially to allow room for the topslide mounting bolts.
Offline Lofty76
Re: An experiment
« Reply #4 on: April 18, 2013, 09:51:31 PM »
Leaving me with this result.
Offline Lofty76
Re: An experiment
« Reply #5 on: April 18, 2013, 09:53:41 PM »
Now had to 'bore' the base, bit like a smokebox saddle really, to match the curvature of the motor, and you can just see the reference line which equates to the center height distance.
Offline Lofty76
Re: An experiment
« Reply #6 on: April 18, 2013, 09:55:42 PM »
The next job was to match the motor mounts to the base, the large 1" hole in the middle of the base is for the topslide locating spigot.
Offline Lofty76
Re: An experiment
« Reply #7 on: April 18, 2013, 09:56:41 PM »
So the motor now sits down like so.
Offline Lofty76
Re: An experiment
« Reply #8 on: April 18, 2013, 09:57:50 PM »
At this point I realised I needed to open up the base to accommodate the start capacitor.
Offline Lofty76
Re: An experiment
« Reply #9 on: April 18, 2013, 09:59:44 PM »
And now to make the locating spigot as shown.
Offline Lofty76
Re: An experiment
« Reply #10 on: April 18, 2013, 10:00:43 PM »
Trial fit on the lathe.
Offline Lofty76
Re: An experiment
« Reply #11 on: April 18, 2013, 10:02:06 PM »
Check for squareness
Offline Lofty76
Re: An experiment
« Reply #12 on: April 18, 2013, 10:04:27 PM »
I wanted to try this out, I know its bad form, but it had to be done, Oppenheimer probably said a similar sort of thing just before the button was pressed.
Offline Lofty76
Re: An experiment
« Reply #13 on: April 18, 2013, 10:05:52 PM »
First attempt.
Offline Lofty76
Re: An experiment
« Reply #14 on: April 18, 2013, 10:07:05 PM »
OK, I'm off to sort the guards out and add a small cooling fan to the spare end, back later  ;)
