Thanks! The water tank is home made. 3" brass tube with a piece of brass plate soldered to close one end. The wooden slats are 3/8"x1/4" basswood from the craft store. I beveled the edges to eliminate gaps then attached them to the brass with VXB tape. Drizzled thin CA glue into the joints then sanded. Cherry gel stain. Brass wire banding. I'll post some tank build pix tomorrow.
Best,
Stan
