Well, the finger engine anywho
This is a mirrored post I've written up on another forum, sorry if you're seeing it twice. Just thought it was about time I put something on here!
Wasn't sure where to put this as it's using someone's measurements and my mind to create it..... If it needs moving I'm sure the powers that be will sort it?
Got a little bored over the Easter break. So thought I'd tidy up the workshop a bit.... That lead me to find a little plan for the NAMES finger engine I've had in a draw for 4 or so years!
Never made it, thought that it looked like a little fun "weekend" project so.....Stuff the tidy up!
Here is where I'm upto after 16 ish hours.... I just can't follow a plan
Warning, this gets artsy fartsy
Started with this... Converted to metric and rough materials cut.
Then start to put the holes in all the right places. First the upright.
A little shaping with the ball turner.
Polished up a little and the micro ball bearings pressed in.
The treadle.
Put the holes in the correct places...
And make it a shape you like the look of.
I used a carbide burr for this bit... Reason being the endmills seem to be a little too grabby in my experience...
You can't let go of this, else there will be a big bang and a few tears!!! :bugeye:
Then the conrod.
Similar use of a burr, 1/8th one this time.... Bends a bit, very small cuts are ok though..
Then make a wooden erm,,, fixture!?
And shape the rod a little..
The cam,
A little narrow!
Think that'll do for now,
There are quite a few more pic's but they're mostly just different angles etc.... Figure you've probably had quite enough pic's in this post by now
I'll hopefully get a little time on the "dreaded flywheel" this weekend?
Dunno why I think cutting these flywheels is so damn tough... Maybe it's because I have to stick to the plan
Possibly more over the weekend?
Ralph.
