Author Topic: Putting a recess in a plate flywheel  (Read 4392 times)
Bogstandard
« on: April 08, 2013, 09:10:16 PM »
This is a requested repost, showing how I recess a plate flywheel.
Doing a recess like this can cause a beginner a few problems, I know it used to cause me a lot of heartache.
Now what I am going to be showing here will cause the purists amongst you to jump up and down, but it is my firm belief that there are no hard and fast rules with regards to grinding tooling, other than if it works, it is right, so what is the problem.
Away we go.
These recesses took less than five minutes per side.
 This picture shows the tooling in question, which will be explained a little later.
 I just can't get good close up shots otherwise I would have shown you the cutter in full profiles.
 This next pic shows the tool in action (but you can't see it, but it does show how the flywheel should be mounted). Mine is mounted into soft jaws, but I would expect you to mount yours into your outside jaws that usually come with the chuck. Do not attempt this with the flywheel on a mandrel, it will not be able to withstand the cutting pressures involved.
 Now to the profile of the tool I use, and please remember, this is how I do it, someone else might do it in a totally different way, this one works for me.
 Using these rough dimensions (not critical) I can recess to about 250 thou deep, but on a 1/2" wide flywheel I will go a max of 200 thou each side.
 There is no easy way to describe how to grind a tool so I am not even going to try, other than to say, keep the tool cool while grinding, grind a bit, quench, if it changes colour dramatically you have already softened the tool, and you will have trouble cutting harder materials.
 This tool is designed just like a boring bar with a cutting edge on the right hand side as well, but stuck onto the end of a nice rigid bit of stock rather than on the end of a flimsy thin bar.
 The angles shown on the sketch are slightly exaggerated to show where the angles should be to give you cutting clearances, somewhere around 5deg. for each one should be ok. The top face of the cutter should be totally level.
 The way to use the tool is mount it very close into your holder, this will keep vibration to a minimum. At the same time square the face of the tool to the job, and get it bob on centre height or if you can't, just slightly below, on no account go higher.
 I use a saddle stop for my in cutting, but you might have to lock your saddle and put the infeed in using your compound slide.
 So, starting at the outside edge of your recess, minus about 10 thou, plunge straight in to your chosen depth minus about 5 thou, retract, move across just less than the width of the cutter and plunge in again. Keep doing this until you are about 10 thou from the size of your centre boss and retract.
 Now you are going to do the finishing cut.
 Saddle still locked, bring the tool out to your outside edge of the recess, then wind in using the compound to your final depth, then wind across with your crosslide and carry on until you hit your size for the boss, then retract, bringing the boss to correct size.
 If you have any slight chatter marks, these can easily be cleaned up with a bit of emery or wire wool.
 My tool has made dozens of recesses in all sorts of materials, mainly non ferrous, but has done mild steel on occasions, and stainless just the once (which I don't want to repeat) and the tooling is still like new, just a slight stone up with an Arkansas stone before use keeps it razor sharp.
I hope you understand it OK
Re: Putting a recess in a plate flywheel
« Reply #1 on: April 08, 2013, 09:41:31 PM »
John I have had a lot of trouble cutting flywheels and resets. I am going to try this and see if it helps me. Is this what is called trepanning? I believe I spelled it correct.
Bogstandard
« Reply #2 on: April 08, 2013, 09:43:23 PM »
Yes Don, you are correct, trepanning.
Offline DaveH
  • Kempton Park. RSA
« Reply #3 on: April 08, 2013, 10:25:40 PM »
Very informative post John.  :ThumbsUp:
DaveH
Offline PeterE
« Reply #4 on: April 08, 2013, 10:35:02 PM »
If I remember correctly from GHTs first book - the model engineers workshop manual - I think he ground up a tool very much like the one described, but he did it from a round piece of HSS. That would probably make it easier to gind, but the depth may not be as big.
BR
/Peter
Arbalest
« Reply #5 on: April 08, 2013, 10:41:53 PM »
Nice pictures John. That's the type of tool I ground for the flywheel on my JR vacuum engine.
Bogstandard
« Reply #6 on: April 08, 2013, 10:45:36 PM »
Peter,
That one is just what I came up with by thinking logically what was required of the tool.
I am sure there are hundreds of different tooling shapes that would have done the same job.
Offline PeterE
« Reply #7 on: April 09, 2013, 09:42:57 PM »
John,
My comment was not any sort of criticism on your tool, just a kind of "have seen that somewhere" other solution that most certainly will work just as good.
The solution is very much logical if the purpose is thought through properly as you have done.
Hope you did not feel offended.
BR
/Peter
Offline NickG
« Reply #8 on: April 09, 2013, 11:07:22 PM »
I can vouch for a tool of this shape,
Wish I had seen this years ago, I always struggled with recesses until I took a step back and as John said thought logically about what was required of the tool.
Bogstandard
« Reply #9 on: April 10, 2013, 01:51:08 AM »
Peter,
No offence taken at all.
In fact, I wish other people would show how they manage to do it, as I said, there must be many ways of skinning this cat.
With just a little thought about shape and clearances, almost any turning job becomes an easy exercise.
