Author Topic: "Indicating" center with an edge finder.  (Read 3076 times)
Offline ricktaylor
« on: April 07, 2013, 05:21:32 PM »
I take half the value of 2 positions to determine the center of the "222" camshaft axle for machining the pushrod latch slot. Another reason to leave your indicator in its box. :) Later, RT.
<a href="https://www.youtube.com/watch?v=NCEASFdccXc" target="_blank">http://www.youtube.com/watch?v=NCEASFdccXc</a>
http://www.youtube.com/user/popnstart/videos
(No ads!! :whoohoo: :pinkelephant:)
Offline kevin45
Re: "Indicating" center with an edge finder.
« Reply #1 on: May 28, 2013, 10:57:16 PM »
Any time that I need to find centers, whether it be between the vise jaws, or splitting a piece in half in the "X" position, I always have touched off, zeroed, went to the opposite side, then divided the value in half. Of course this is when having a digital readout. No matter what I make, I like to work off of center instead of one end. I find that most parts, when looking at squares and rounds are mostly symmetrical. It is not that way all of the time, but with the majority of parts, there is a center. One reason I like doing the work off of the center is that if you have a piece a tick longer than 6", then you machine one end in a 6" vise, then you go to the other end and mill that end off to clean things up. It also depends on what the part is, but for the most part, I like to work off of center.
