Very nice. Are you going to run it in diesel mode? I have access to a waterjet cutter at the local Tech Shop that will cut up to 6" steel, but it is fairly expensive.Chuck
I'm digging it! I've pondered doing an engine block this way before...so I'm watching intently!Dave
Sounds like "slater's letters" which I did mention on ME. They should not get too hot on the crankcase so expect you will be OK.https://slatersplastikard.com/assets/pdfs/AlphabetFlyer.pdfJ
