Author Topic: Lister 6/1 Diesel  (Read 79227 times)
Offline HobbyNut
  • Surrey BC
    • What I do
Lister 6/1 Diesel
« on: April 03, 2013, 03:59:30 PM »
Hi, new to your board here, but I do recognize some other posters.
I am starting to build the Lister diesel that is being published in Model Engineer. It is by a fellow Aus. which is what interested me to start, as well as the fact that I had experience with them back 50 years or so.
If anyone is interested, I will post some pics here as I go.
Pat.
PatO
I started out with nothing, I still have most of it left.
Re: Lister 6/1 Diesel
« Reply #1 on: April 03, 2013, 04:08:17 PM »
Have at it Pat!  Welcome!
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #2 on: April 03, 2013, 04:15:19 PM »
All I have to do is figure out how to post pics here!!!
PatO
« Reply #3 on: April 03, 2013, 04:29:02 PM »
You either need to have the images hosted somewhere, the ones you have on ME will do just go into albums and click so the picture so it is not a thumbnail then right click, properties and copy the url. Then click the insert image icon (next to youtube) on here and paste ithe url between the ] and [
Or you can just add them straight from your computer as attachments, at the bottom of the box you post a reply in you will see " + Attachments and other options" should be self explainitary from there.
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #4 on: April 03, 2013, 04:45:09 PM »
Tried the attachments option Jason, and hit preview, and nothing appeared, so I may try the link method. Thanks for your help, both here and over there.
PatO
« Reply #5 on: April 03, 2013, 05:04:02 PM »
The images won't show in preview, only at the bottom when the reply is posted. something like this, the large image is using the insert image, in this case from ME and the thumbnail from that image which I saved on my computer.
« Last Edit: April 03, 2013, 05:07:17 PM by Jasonb »
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #6 on: April 03, 2013, 05:34:13 PM »
Ah, I see that you are clever with this stuff....I am still learning!
See if this turns out.
OK, it works.
This is the end plate for the crankcase. Waterjet cut from 2" MS plate.
« Last Edit: April 03, 2013, 06:14:23 PM by HobbyNut »
PatO
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #7 on: April 03, 2013, 05:37:58 PM »
These are some more waterjet cut plates for the crankcase.
« Last Edit: April 03, 2013, 06:14:54 PM by HobbyNut »
PatO
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #8 on: April 03, 2013, 05:39:18 PM »
All the pieces tacked together.
« Last Edit: April 03, 2013, 06:15:34 PM by HobbyNut »
PatO
« Reply #9 on: April 03, 2013, 05:49:22 PM »
I think you may need to resize the images a bit before adding them as attachments, when the thumb is clicked they come up too big and need scrolling to view. Try about 700 wide.
« Reply #10 on: April 03, 2013, 05:55:30 PM »
It looks really good Pat  :ThumbsUp:
Looking forward to seeing more of it.
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #11 on: April 03, 2013, 06:17:27 PM »
Fixed them Jason, thanks.
The pieces are slightly different to the plans around the cover plate. I may redo them.
PatO
Offline Bearcar1
  • Chicagoland Area, USA
« Reply #12 on: April 03, 2013, 06:22:43 PM »
Wow! This is going to a fun build to watch. Nice plate work, Hob'. :ThumbsUp:
BC1
Offline Farmboy
  • England
« Reply #13 on: April 03, 2013, 10:12:28 PM »
Wow, indeed! I shall certainly be watching this one.
A full size 6/1 played a big part in my early life. I lost count of the number of times I had the head off for a de-coke . . . it was running way too light a load, and had about 10 feet of 2" water pipe for an exhaust.
Looking good so far  :ThumbsUp:
Mike.
Offline HobbyNut
  • Surrey BC
    • What I do
« Reply #14 on: April 03, 2013, 11:51:46 PM »
Just so everybody is in the know.
I am building this from plans that are being serialized in ME.
It was originally built by George Punter. He used castings that he made himself. I am not so talented, so I decided to fabricate it entirely from "barstock" and sheet steel, aluminum and brass.
I am also building a Steam locomotive and a traction engine, both also from barstock.
PatO
